ERR_INVALID_RESPONSE beim Versuch, push_service_worker.js zu erhalten
I’m running Discourse in a docker container behind a reverse proxy with Apache, so my app.yml config file is
expose:
- “8080:80” # http
- “4443:443” # https
The reverse proxy works for http connections. I installed a ssl certificate with letsencrypt as explained here, and it works too.
Chrome Developer Tools show that if fails to GET push-service-worker.js
Browsing https://foro.soybiotec.es/push-service-worker.js in Chrome gives Discourse custom error 404 page. What could be the problem here?
Why are you exposing 4443 if https is done on Apache?
@Falco At first I thought the way to have a https would be to have another reverse proxy, same as for http.
Did you enable the plugin on settings? Also is force_ssl enabled?
I had just uninstalled the plugin for testing. Installed and activated and error disappears. Sorry for being so dummy. I thought I had found the reason why Push Notifications don’t work for me.
