アップグレード v2.2.0.beta5 +175 後のエラー 500
Hello everyone,
Since three months now, I moved my 13-year-old forum (with vBulletin) - to Discourse - and I’m totally happy! Until today everything worked fine and the few bugs that I had, just I solve with a new update via command line.
But until today, after updating on both tracks, users can not log in, “Error Unknown” appears.
And also cant’ enter the profile of users either because it shows an error page. :worried:
These are logs that show me:
var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activemodel-5.2.2/lib/active_model/attribute_methods.rb:430:in `method_missing'
/var/www/discourse/plugins/twitter-profile-link/plugin.rb:15:in `block (2 levels) in activate!'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:375:in `include?'
(eval):76:in `_fast_attributes'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:468:in `rescue in attributes'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:455:in `attributes'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:343:in `as_json'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/json/encoding.rb:35:in `encode'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/json/encoding.rb:22:in `encode'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/core_ext/object/json.rb:41:in `to_json'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:331:in `to_json'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/multi_json-1.13.1/lib/multi_json/adapters/oj.rb:40:in `dump'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/multi_json-1.13.1/lib/multi_json/adapter.rb:25:in `dump'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/multi_json-1.13.1/lib/multi_json.rb:139:in `dump'
/var/www/discourse/app/controllers/application_controller.rb:453:in `render_json_dump'
/var/www/discourse/app/controllers/users_controller.rb:88:in `block (2 levels) in show'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/mime_responds.rb:203:in `respond_to'
/var/www/discourse/app/controllers/users_controller.rb:80:in `show'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.2/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.1/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/conditional_get.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:216:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.3.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.1/lib/mini_profiler/profiler.rb:171:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.2.0.pre.1/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:180:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>'
Any ideas or help to fix this?
It looks like the twitter profile link plugin is not compatible? Try removing it and rebuilding?
I’ve just pushed a fix to the plugin. You should be able to add the plugin back and rebuild now:
https://github.com/discourse/twitter-profile-link/commit/0092677287df9fb6b670d6eb75fba2d7b16296a7
Great, great, great! that works and this problema is fixed now. :facepunch:
And since we are, I am seeing in the logs, another error, although it is only a warning
TypeError: Cannot set property 'unanswered' of undefined
    at https://<mysite>.com/theme-javascripts/f42a16d36493e4773b85153d5c8e43d532404c21.js?__ws=<mysite>.com:8:46
    at https://<mysite>.com/theme-javascripts/f42a16d36493e4773b85153d5c8e43d532404c21.js?__ws=<mysite>.com:20:4
These who can be? I have these continuous one after another :roll_eyes:
That means it is one of your themes. Have a look at your themes and see if there’s anything that needs updating. If not, try removing them one by one to isolate the source of the problem.
