Hey,
I’m fairly new to discourse but trying to get it running. However, I was able to install a fresh discourse and it worked perfect. After that I imported existing data from an old phpbb platform. This also worked pretty well but after trying to start the app, I received the following error:
root@Ubuntu-1604-xenial-64-minimal ~ # /var/discourse/launcher start app
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: driver failed programming external connectivity on endpoint app (968b81cbbd373c581d13a6f733ceba1a3b04aceaf292ecc51141fb26f133c7bf): Bind for 0.0.0.0:443 failed: port is already allocated
Error: failed to start containers: app
netstat:
root@Ubuntu-1604-xenial-64-minimal ~ # netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1027/sshd
tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      17467/postgres
tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      28390/redis-server
tcp6       0      0 :::22                   :::*                    LISTEN      1027/sshd
tcp6       0      0 :::443                  :::*                    LISTEN      14632/docker-proxy
tcp6       0      0 :::6379                 :::*                    LISTEN      28428/redis-server
tcp6       0      0 :::80                   :::*                    LISTEN      14644/docker-proxy
udp        0      0 0.0.0.0:68              0.0.0.0:*                           788/dhclient
I had vsftpd and mysql on the server but removed it. Any ideas on how to solve the issue?
Thanks,
Daniel
