Error when create user passkey in browser
when i try to create passkey in my own site, it reminds
The passkey registration process either timed out, was cancelled or is not allowed
but i can create passkey in discourse meta forum in same browser(mirosoft edge) and same plugin( apple passkey)
i have upgraded my discourse to latest, but it doesn’t work like this post
Hey, it looks like we do show a console error when this message you share shows up in a dialog.
Could you open your browser console and share with us the error you might see?
it seems like there is nothing about this error in logs
You’ll need to see your browser console log, not site /logs.
is this right?
forum.beginner.center/:1  Mixed Content: The page at 'https://forum.beginner.center/' was loaded over HTTPS, but requested an insecure font 'http://forum.beginner.center/fonts/JetBrainsMono-Regular.woff2?v=0.0.19'. This request has been blocked; the content must be served over HTTPS.
forum.beginner.center/:1  Mixed Content: The page at 'https://forum.beginner.center/' was loaded over HTTPS, but requested an insecure font 'http://forum.beginner.center/fonts/JetBrainsMono-Bold.woff2?v=0.0.19'. This request has been blocked; the content must be served over HTTPS.
app.js:270 ℹ️ Discourse v3.5.0.beta9-dev — https://github.com/discourse/discourse/commits/33dfd7dba9 — Ember v5.12.0
[Report Only] Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'nonce-4YvvTZffYuqGaENC8DnQ7yeNg' 'strict-dynamic'".
analytics.eu.umami.is/script.js:1   Failed to load resource: net::ERR_CONNECTION_CLOSED
Tracking Prevention blocked access to storage for <URL>.
deprecated.js:62  Deprecation notice: Setting timezone property of user object is deprecated. Use user_option object instead [deprecated since Discourse 2.9.0.beta12] [removal in Discourse 3.0.0.beta1] [deprecation id: discourse.user.userOptions]
a @ deprecated.js:62
security:1 Autofocus processing was blocked because a document already has a focused element.
completion_list.html:14   GET chrome-extension://mfbcdcnpokpoajjciilocoachedjkima/heuristicsRedefinitions.js net::ERR_FILE_NOT_FOUND
completion_list.html:13   GET chrome-extension://mfbcdcnpokpoajjciilocoachedjkima/extensionState.js net::ERR_FILE_NOT_FOUND
completion_list.html:12   GET chrome-extension://mfbcdcnpokpoajjciilocoachedjkima/utils.js net::ERR_FILE_NOT_FOUND
ajax.js:188   POST https://forum.beginner.center/u/register_passkey.json 401 (Unauthorized)
send @ jquery.js:9940
ajax @ jquery.js:9521
o @ ajax.js:188
(匿名) @ rsvp-DaQAFb0W.js:435
e @ rsvp-DaQAFb0W.js:451
A @ ajax.js:201
registerPasskey @ user.js:650
createPasskey @ user-passkeys.gjs:86
await in createPasskey
didConfirm @ user-passkeys.gjs:140
didConfirmWrapped @ dialog.js:134
_join @ index.js:788
join @ index.js:605
p @ index.js:152
(匿名) @ index.js:250
submit @ confirm-session.gjs:84
await in submit
(匿名) @ d-button.gjs:138
invoke @ index.js:264
flush @ index.js:180
flush @ index.js:334
_end @ index.js:762
end @ index.js:565
_runExpiredTimers @ index.js:869
setTimeout
setTimeout @ index.js:39
_installTimerTimeout @ index.js:912
_later @ index.js:823
later @ index.js:652
T @ index.js:562
_triggerAction @ d-button.gjs:135
click @ d-button.gjs:93
user-passkeys.gjs:104  {jqXHR: {…}, textStatus: 'error', errorThrown: ''}errorThrown: ""jqXHR: abort: ƒ (e)always: ƒ ()catch: ƒ (e)done: ƒ ()fail: ƒ ()getAllResponseHeaders: ƒ ()getResponseHeader: ƒ (e)jqTextStatus: "error"overrideMimeType: ƒ (e)pipe: ƒ ()progress: ƒ ()promise: ƒ (e)readyState: 4requestedUrl: "/u/register_passkey.json"responseJSON: {errors: Array(1)}responseText: "{\"errors\":[\"The origin of the authentication request does not match the server origin.\"]}"setRequestHeader: ƒ (e,t)state: ƒ ()status: 401statusCode: ƒ (e)statusText: "error"then: ƒ (e,i,n)[[Prototype]]: ObjecttextStatus: "error"[[Prototype]]: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()__proto__: (...)get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()
createPasskey @ user-passkeys.gjs:104
join @ index.js:605
p @ index.js:152
(匿名) @ index.js:250
await in submit
_end @ index.js:762
end @ index.js:565
setTimeout
T @ index.js:562
Oh hmm this is useful but 401s can be triggered by a myriad of reasons. Will check with our resident passkeys expert.
Can you make sure your site is configured to serve everything in https? Passkey challenge verification requires that all requests go through https. Also the domain between browser and server must match exactly. If there is a mismatch somewhere, the verification will fail.
We have a setting for this, force_https, you can try that, it may help (though be careful, it might also lock you out if server isn’t configured properly).
this is my app.yml
i am using reverse proxy by OpenResty (based on nginx)
expose:
  - "6180:80"   # http
  - "6443:443" # https
  - "587:587"
i can’t use my site by https port 6443
so i only set reverse proxy of http
this is my OpenResty config
server {
    listen 80 ;
    listen 443 ssl http2 ;
    server_name forum.beginner.center;
    index index.php index.html index.htm default.php default.htm default.html;
    proxy_set_header Host $host;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Host $server_name;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection $http_connection;
    access_log /www/sites/forum.beginner.center/log/access.log main;
    error_log /www/sites/forum.beginner.center/log/error.log;
    location ^~ /.well-known/acme-challenge {
        allow all;
        root /usr/share/nginx/html;
    if ($scheme = http) {
        return 301 https://$host$request_uri;
    ssl_certificate /www/sites/forum.beginner.center/ssl/fullchain.pem;
    ssl_certificate_key /www/sites/forum.beginner.center/ssl/privkey.pem;
    ssl_protocols TLSv1.3 TLSv1.2 TLSv1.1 TLSv1;
    ssl_ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:!aNULL:!eNULL:!EXPORT:!DSS:!DES:!RC4:!3DES:!MD5:!PSK:!KRB5:!SRP:!CAMELLIA:!SEED;
    ssl_prefer_server_ciphers on;
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 10m;
    error_page 497 https://$host$request_uri;
    proxy_set_header X-Forwarded-Proto https;
    add_header Strict-Transport-Security "max-age=31536000";
    include /www/sites/forum.beginner.center/proxy/*.conf;
this is reverse proxy config
location ^~ / {
    proxy_pass http://127.0.0.1:6180;
    proxy_set_header REMOTE-HOST $remote_addr;
    proxy_set_header X-Forwarded-Proto $scheme;
    add_header X-Cache $upstream_cache_status;
    add_header Cache-Control no-cache;
    proxy_ssl_server_name off;
    proxy_ssl_name $proxy_host;
hello, anyone can help me?
Sorry for the delay. The issue here is indeed related to your proxy. I can’t exactly say what it is, but one of domain name, protocol (http or https) and port are getting in the way.
Passkeys verify that the frontend and backend both run on the same domain, protocol and port. If one of these is a mismatch, you’ll get an error like this.
In the Rails CLI, can you try this:
DiscourseWebauthn.origin
and compare it to the URL that you use to access the site in the browser? The two should match.
user passkey function worked when i enable force https
