خطأ عند ترقية Discourse
Hi there. I got this error when upgrading Discourse. Do you guys know how to solve it?
here is my discourse version
<meta name="generator" content="Discourse 3.4.0.beta2-dev - https://github.com/discourse/discourse version 41c3c5745e0611828cb6ed84e5e625faf12df13a">
Operating-System information
NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.6 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
docker version
Docker version 26.1.0, build 9714adc
/var/discourse/containers/app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  EMBER_CLI_PROD_ASSETS: 1
  UNICORN_WORKERS: 4
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: discourse.abcdef.com
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'email@abcdef.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: yummy@abcdef.com
  DISCOURSE_SMTP_PASSWORD: "aaaaaaaaaaaaaaaaaaaaaaaa-bbbbbbbb-ccccccccccc"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  DISCOURSE_SMTP_DOMAIN: abcdef.com
  DISCOURSE_NOTIFICATION_EMAIL: yummy@abcdef.com
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: yummy@abcdef.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-math.git
          - git clone https://github.com/discourse/discourse-chat-integration.git
          - git clone https://github.com/discourse/discourse-cakeday.git
          - git clone https://github.com/discourse/discourse-akismet.git
          - git clone https://github.com/discourse/discourse-github.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-translator.git
          - git clone https://github.com/discourse/discourse-code-review.git
          - git clone https://github.com/discourse/discourse-voting.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
          - git clone https://github.com/discourse/discourse-reactions.git
          - git clone https://github.com/discourse/discourse-automation.git
          - git clone https://github.com/discourse/discourse-tooltips.git
          - git clone https://github.com/discourse/discourse-assign.git
          - git clone https://github.com/discourse/discourse-encrypt.git
          - git clone https://github.com/discourse/discourse-rss-polling.git
          - git clone https://github.com/discourse/discourse-user-card-badges.git
          - git clone https://github.com/discourse/discourse-teambuild.git
          - git clone https://github.com/discourse/discourse-prometheus.git
          - git clone https://github.com/discourse/discourse-calendar.git
          - git clone https://github.com/discourse/discourse-docs.git
          - git clone https://github.com/discourse/discourse-gamification.git
          - git clone https://github.com/discourse/discourse-bbcode-color.git
          - git clone https://github.com/discourse/discourse-follow.git
          - git clone https://github.com/discourse/discourse-templates.git
          - git clone https://github.com/discourse/discourse-shared-edits.git
          - git clone https://github.com/discourse/discourse-category-experts.git
          - git clone https://github.com/discourse/discourse-graphviz.git
          - git clone https://github.com/discourse/discourse-post-voting.git
          - git clone https://github.com/discourse/discourse-saved-searches.git
          - git clone https://github.com/discourse/discourse-staff-alias.git
          - git clone https://github.com/discourse/discourse-policy.git
          - git clone https://github.com/discourse/discourse-whos-online.git
          - git clone https://github.com/discourse/discourse-bcc.git
          - git clone https://github.com/discourse/discourse-ai.git
          - git clone https://github.com/discourse/discourse-algolia.git
run:
this is the command that I issued to upgrade Discourse.
cd /var/discourse
./launcher rebuild app
error
I, [2025-04-10T15:51:32.679706 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2025-04-10T15:51:33.940918 #1]  INFO -- : Successfully installed bundler-2.6.4
1 gem installed
I, [2025-04-10T15:51:33.941573 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2025-04-10T15:51:39.190810 #1]  INFO -- :
I, [2025-04-10T15:51:39.191737 #1]  INFO -- : > cd /var/www/discourse && if [ -f yarn.lock ]; then
  if [ -d node_modules/.pnpm ]; then
    echo "This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up..."
    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +
  fi
  su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
else
  su discourse -c 'CI=1 pnpm install --frozen-lockfile'
fi
I, [2025-04-10T15:51:44.558550 #1]  INFO -- : Detected yarn-managed node_modules. Performing one-time cleanup...
cleanup done
 ERR_PNPM_UNSUPPORTED_ENGINE  Unsupported environment (bad pnpm and/or Node.js version)
Your Node version is incompatible with "/var/www/discourse".
Expected version: >= 20
Got: v18.20.4
This is happening because the package's manifest has an engines.node field specified.
To fix this issue, install the required Node version.
I, [2025-04-10T15:51:44.559546 #1]  INFO -- : Terminating async processes
I, [2025-04-10T15:51:44.559682 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 36
I, [2025-04-10T15:51:44.559994 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 104
104:signal-handler (1744300304) Received SIGTERM scheduling shutdown...
2025-04-10 15:51:44.560 UTC [36] LOG:  received fast shutdown request
2025-04-10 15:51:44.581 UTC [36] LOG:  aborting any active transactions
104:M 10 Apr 2025 15:51:44.585 # User requested shutdown...
104:M 10 Apr 2025 15:51:44.586 * Saving the final RDB snapshot before exiting.
2025-04-10 15:51:44.591 UTC [36] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2025-04-10 15:51:44.598 UTC [46] LOG:  shutting down
2025-04-10 15:51:44.634 UTC [36] LOG:  database system is shut down
104:M 10 Apr 2025 15:51:44.947 * DB saved on disk
104:M 10 Apr 2025 15:51:44.948 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && if [ -f yarn.lock ]; then
  fi
else
fi failed with return #<Process::Status: pid 649 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ -f yarn.lock ]; then\n  if [ -d node_modules/.pnpm ]; then\n    echo \"This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up...\"\n    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +\n  fi\n  su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'\nelse\n  su discourse -c 'CI=1 pnpm install --frozen-lockfile'\nfi"]}
e6f9cd9a001c3b9e1208284621b73506ba021b2350e0c9cca235941538863fd9
node verion in current discourse-image
ما هو ذاكرة الخادم الخاص بك؟  هل قمت بإعداد ملف التبديل؟
مرحباً.
هذه هي معلومات الذاكرة وملف المبادلة لدينا
free -h
              total        used        free      shared  buff/cache   available
Mem:          3.8Gi       2.1Gi       274Mi       275Mi       1.5Gi       1.2Gi
Swap:         2.0Gi       117Mi       1.9Gi
لا يسعني إلا أن أخمن أن سبب الخطأ هو إما القفزة الكبيرة في الإصدارات - حوالي 7 أشهر من التحديثات - أو العدد الكبير من الإضافات.
أول شيء سأحاوله هو تكرار تحديث سطر الأوامر. أعتقد أن هذا يمكن أن يساعد، وهذا ليس مجرد خرافة!
الشيء الثاني الذي سأحاوله هو التعليق على جميع الإضافات الخاصة بك من ملف yml، وحاول التحديث مرة أخرى. إذا نجح الأمر، يمكنك إعادتها، ربما دفعة واحدة أو ربما بحذر أكبر.
ولكن ربما سيكون لدى شخص آخر نصيحة أكثر استنارة.
(في منتدى الخاص بي، الآن في 3.5.0.beta2-dev، لدي إصدار العقدة v22.14.0)
هل يمكنك مشاركة مخرجات الأمر docker images من فضلك؟ يبدو أنك عالق في صورة حاوية قديمة بطريقة ما.
مرحباً. أعتقد أن هذا هو ما طلبته
REPOSITORY                 TAG                 IMAGE ID       CREATED         SIZE
local_discourse/app        latest              dfd8027ee473   6 months ago    4.75GB
discourse/base             2.0.20240825-0027   9dc96b6115cb   7 months ago    3.38GB
لم ينجح
لم أقم بذلك بعد. سأختبره في بيئة التطوير. شكرًا لك
نعم، كما شككت يبدو أنك قد علقت بطريقة ما في صورة قديمة.
ما هو ناتج الأمر
cd /var/discourse
git pull
مرحباً فالكو. إليك الناتج
git pull origin main
From https://github.com/discourse/discourse_docker
 * branch            main       -> FETCH_HEAD
Removing launcher_go/v2/utils/utils_suite_test.go
Removing launcher_go/v2/utils/find_config_test.go
Removing launcher_go/v2/utils/find_config.go
Removing launcher_go/v2/utils/consts.go
Removing launcher_go/v2/utils/cmd_runner.go
Removing launcher_go/v2/test_utils/utils.go
Removing launcher_go/v2/test/templates/web.template.yml
Removing launcher_go/v2/test/containers/web_only.yml
Removing launcher_go/v2/test/containers/test3.not-a-yaml
Removing launcher_go/v2/test/containers/test2.yaml
Removing launcher_go/v2/test/containers/test.yml
Removing launcher_go/v2/test/containers/standalone.yml
Removing launcher_go/v2/main.go
Removing launcher_go/v2/go_suite_test.go
Removing launcher_go/v2/go.sum
Removing launcher_go/v2/go.mod
Removing launcher_go/v2/docker/docker_suite_test.go
Removing launcher_go/v2/docker/commands_test.go
Removing launcher_go/v2/docker/commands.go
Removing launcher_go/v2/config/config_test.go
Removing launcher_go/v2/config/config_suite_test.go
Removing launcher_go/v2/config/config.go
Removing launcher_go/v2/cli_runtime_test.go
Removing launcher_go/v2/cli_runtime.go
Removing launcher_go/v2/cli_build_test.go
Removing launcher_go/v2/cli_build.go
Removing launcher_go/v2/bin/.gitignore
Removing launcher_go/v2/Makefile
Removing launcher_go/README.md
Removing image/monitor/src/monitor.rb
Removing image/monitor/Dockerfile
Removing image/discourse_fast_switch/create_switch.rb
Removing image/discourse_fast_switch/Dockerfile
Removing image/discourse_bench/run_bench.sh
Removing image/discourse_bench/Dockerfile
Auto-merging .gitignore
Removing .github/workflows/launcher_go.yml
Merge made by the 'recursive' strategy.
 .github/workflows/build.yml                     |  65 +++++++++++++++++++++--------
 .github/workflows/launcher_go.yml               |  45 --------------------
 .gitignore                                      |   1 +
 README.md                                       |   7 +++-
 discourse-setup                                 |   4 +-
 image/README.md                                 |  12 +-----
 image/auto_build.rb                             |  16 ++++++-
 image/base/Dockerfile                           | 160 ++++++++++++++++++++++++++++++++++++++++++-----------------------------
 image/base/install-imagemagick                  |  27 ++++++------
 image/base/install-jemalloc                     |   6 +--
 image/base/install-nginx                        |   4 +-
 image/base/install-oxipng                       |   8 +++-
 image/base/install-redis                        |   4 +-
 image/base/install-rust                         |   2 +-
 image/discourse_bench/Dockerfile                |  34 ---------------
 image/discourse_bench/run_bench.sh              |  19 ---------
 image/discourse_dev/postgres_dev.template.yml   |  10 +---
 image/discourse_fast_switch/Dockerfile          |  23 -----------
 image/discourse_fast_switch/create_switch.rb    |  25 -----------
 image/discourse_test/Dockerfile                 |   7 +--
 image/monitor/Dockerfile                        |  13 ------
 image/monitor/src/monitor.rb                    |  98 -------------------------------------------
 launcher                                        |   4 +-
 launcher_go/README.md                           | 134 -----------------------------------------------------------
 launcher_go/v2/Makefile                         |  10 -----
 launcher_go/v2/bin/.gitignore                   |   1 -
 launcher_go/v2/cli_build.go                     | 180 -------------------------------------------------------------------------------
 launcher_go/v2/cli_build_test.go                | 254 ----------------------------------------------------------------------------------------------------------------
 launcher_go/v2/cli_runtime.go                   | 373 --------------------------------------------------------------------------------------------------------------------------------------------------------------------
 launcher_go/v2/cli_runtime_test.go              | 204 ------------------------------------------------------------------------------------------
 launcher_go/v2/config/config.go                 | 231 ------------------------------------------------------------------------------------------------------
 launcher_go/v2/config/config_suite_test.go      |  13 ------
 launcher_go/v2/config/config_test.go            |  61 ---------------------------
 launcher_go/v2/docker/commands.go               | 324 ----------------------------------------------------------------------------------------------------------------------------------------------
 launcher_go/v2/docker/commands_test.go          |  43 -------------------
 launcher_go/v2/docker/docker_suite_test.go      |  13 ------
 launcher_go/v2/go.mod                           |  30 --------------
 launcher_go/v2/go.sum                           |  64 -----------------------------
 launcher_go/v2/go_suite_test.go                 |  18 --------
 launcher_go/v2/main.go                          |  92 -----------------------------------------
 launcher_go/v2/test/containers/standalone.yml   | 109 ------------------------------------------------
 launcher_go/v2/test/containers/test.yml         | 121 -----------------------------------------------------
 launcher_go/v2/test/containers/test2.yaml       |   0
 launcher_go/v2/test/containers/test3.not-a-yaml |   0
 launcher_go/v2/test/containers/web_only.yml     | 114 --------------------------------------------------
 launcher_go/v2/test/templates/web.template.yml  | 443 -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
 launcher_go/v2/test_utils/utils.go              |  42 -------------------
 launcher_go/v2/utils/cmd_runner.go              |  28 -------------
 launcher_go/v2/utils/consts.go                  |  50 ----------------------
 launcher_go/v2/utils/find_config.go             |  51 -----------------------
 launcher_go/v2/utils/find_config_test.go        |  39 ------------------
 launcher_go/v2/utils/utils_suite_test.go        |  13 ------
 templates/import/phpbb3.template.yml            |   5 ++-
 templates/postgres.10.template.yml              |   3 +-
 templates/postgres.12.template.yml              |   3 +-
 templates/postgres.13.template.yml              | 175 ++++++++++++++++++++++++++------------------------------------------------
 templates/postgres.15.template.yml              |  53 +++++++++++-------------
 templates/postgres.9.5.template.yml             |   3 +-
 templates/postgres.template.yml                 |  96 +++++++++++++++++++++++++------------------
 templates/web.socketed.template.yml             |   4 +-
 templates/web.ssl.template.yml                  |  32 +++++++--------
 templates/web.template.yml                      |  12 ++----
 62 files changed, 382 insertions(+), 3653 deletions(-).
 delete mode 100644 .github/workflows/launcher_go.yml
 delete mode 100644 image/discourse_bench/Dockerfile
 delete mode 100644 image/discourse_bench/run_bench.sh
 delete mode 100644 image/discourse_fast_switch/Dockerfile
 delete mode 100644 image/discourse_fast_switch/create_switch.rb
 delete mode 100644 image/monitor/Dockerfile
 delete mode 100644 image/monitor/src/monitor.rb
 delete mode 100644 launcher_go/README.md
 delete mode 100644 launcher_go/v2/Makefile
 delete mode 100644 launcher_go/v2/bin/.gitignore
 delete mode 100644 launcher_go/v2/cli_build.go
 delete mode 100644 launcher_go/v2/cli_build_test.go
 delete mode 100644 launcher_go/v2/cli_runtime.go
 delete mode 100644 launcher_go/v2/cli_runtime_test.go
 delete mode 100644 launcher_go/v2/config/config.go
 delete mode 100644 launcher_go/v2/config/config_suite_test.go
 delete mode 100644 launcher_go/v2/config/config_test.go
 delete mode 100644 launcher_go/v2/docker/commands.go
 delete mode 100644 launcher_go/v2/docker/commands_test.go
 delete mode 100644 launcher_go/v2/docker/docker_suite_test.go
 delete mode 100644 launcher_go/v2/go.mod
 delete mode 100644 launcher_go/v2/go.sum
 delete mode 100644 launcher_go/v2/go_suite_test.go
 delete mode 100644 launcher_go/v2/main.go
 delete mode 100644 launcher_go/v2/test/containers/standalone.yml
 delete mode 100644 launcher_go/v2/test/containers/test.yml
 delete mode 100644 launcher_go/v2/test/containers/test2.yaml
 delete mode 100644 launcher_go/v2/test/containers/test3.not-a-yaml
 delete mode 100644 launcher_go/v2/test/containers/web_only.yml
 delete mode 100644 launcher_go/v2/test/templates/web.template.yml
 delete mode 100644 launcher_go/v2/test_utils/utils.go
 delete mode 100644 launcher_go/v2/utils/cmd_runner.go
 delete mode 100644 launcher_go/v2/utils/consts.go
 delete mode 100644 launcher_go/v2/utils/find_config.go
 delete mode 100644 launcher_go/v2/utils/find_config_test.go
 delete mode 100644 launcher_go/v2/utils/utils_suite_test.go
اسحب مرة أخرى.
Already up to date.
الآن بعد أن قمت بالتحديث، جرب إعادة البناء.
هذه هي الخطوات التي استخدمتها لترقية discourse. لقد نجحت
@Falco @Ed_S شكراً لمساعدتكما
cd /var/discourse
نجحت هذه الحلول (متبوعة بإعادة بناء) بالنسبة لي أيضًا. شكرًا لك!
شيلا روث
