안녕하세요,
외부 SSO 엔드포인트와 Discourse를 연동하려고 시도하고 있는데, 서명이 일치하지 않는 것 같습니다.
로그에는 다음과 같은 내용이 표시됩니다:
[2020-12-23 21:10:50 +0000] [7] [DEBUG] 2d9c3e07e2e7551e51af471ca3b50e83d06411b2c75e443f96def5b6a257d141
[2020-12-23 21:10:50 +0000] [7] [DEBUG] ad02fdc5bd85adce7722bc264352cca9b931392735ed72474966c4461f188b8c
[2020-12-23 21:10:50 +0000] [7] [DEBUG] compare_digest is different
무엇을 잘못하고 있을까요? hmac 준비 과정은 정상적으로 보이나요?
endpoint:
@app.route(/discourse)
def discourse():
try:
cookie = request.cookies['__session']
except KeyError:
logging.error("Session cookie was not present")
return redirect(login_url)
try:
decoded_token = verify_session_cookie(cookie, check_revoked=True)
except ValueError:
return {"message": "Session cookie was present but not a valid string or empty"}, 400
except ExpiredSessionCookieError:
return {"message": "Session cookie was present but expired."}, 400
try:
uid = decoded_token['uid']
except KeyError:
return {"message": "The user id could not be read from the decoded token"}, 500
try:
payload = request.args['sso']
except KeyError:
return {"message": "Payload parameter was not present"}, 400
try:
sig = request.args['sig']
except KeyError:
return {"message": "Sig parameter was not present"}, 400
try:
nonce = validate_sso_and_generate_nonce(payload, sig, sso_secret)
except DiscourseError as e:
current_app.logger.error("sso validation failed: " + str(e))
user = get_user(uid)
sso_url = generate_sso_redirect_url(forum_url, nonce, sso_secret, user.email, uid, user.display_name, user.display_name)
current_app.logger.debug("Discourse endpoint complete")
return redirect(sso_url)
서명을 생성하는 부분입니다:
def validate_sso_and_generate_nonce(payload, signature, secret):
payload: Discourse가 SSO 엔드포인트로 HTTP 호출 시 sso GET 파라미터로 제공하는 값
signature: Discourse가 SSO 엔드포인트로 HTTP 호출 시 sig GET 파라미터로 제공하는 값
secret: Discourse sso secret에 입력한 시크릿 키
반환 값: discourse가 리다이렉트 URL을 검증하는 데 사용되는 nonce
if None in [payload, signature]:
raise DiscourseError('No SSO payload or signature.')
if not secret:
raise DiscourseError('Invalid secret..')
if not payload:
raise DiscourseError('Invalid payload..')
payload = bytes(parse.unquote(payload), encoding='utf-8')
decoded = base64.decodestring(payload).decode('utf-8')
if len(payload) == 0 or 'nonce' not in decoded:
h = hmac.new(base64.b64encode(bytes(secret, encoding='utf-8')), payload, digestmod=hashlib.sha256)
this_signature = h.hexdigest()
current_app.logger.debug(this_signature)
current_app.logger.debug(signature)
#if this_signature != signature:
# raise DiscourseError('Payload does not match signature.')
if not hmac.compare_digest(this_signature, signature):
current_app.logger.debug("compare_digest is different")
nonce = decoded.split('=')[1]
return nonce
