The user spectre encountered a bootstrap failure due to a missing LETSENCRYPT_ACCOUNT_EMAIL environment variable, which was resolved after reconfiguring via ./discourse-setupdarkpixlz. However, a new issue arose: a “Secure Connection Failed” error (PR_END_OF_FILE_ERROR) on meta.mypage.com, likely due to SSL certificate issues spectre. darkpixlz suggested it’s not a Discourse-specific problem, while Stephen asked about browser compatibility and rebuild attempts. spectre realized the SSL certificates might be causing the error and asked how long to wait for resolution. pfaffman noted it could take up to a week or recommended switching subdomains if DNS is properly configured. spectre confirmed they’re open to changing the subdomain and asked if simply updating the app.yml with the new hostname, SMTP, and email settings would suffice after a rebuild. Stephen confirmed this approach is mostly valid, though some post-rebuild steps may be needed for renamed communities.
FAILED
Pups::ExecError: if [ -z "$LETSENCRYPT_ACCOUNT_EMAIL" ]; then echo "LETSENCRYPT_ACCOUNT_EMAIL ENV variable is required and has not been set."; exit 1; fi failed with return #<Process::Status: pid 2068 exit 1>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cmd"=>["if [ -z \"$LETSENCRYPT_ACCOUNT_EMAIL\" ]; then echo \"LETSENCRYPT_ACCOUNT_EMAIL ENV variable is required and has not been set.\"; exit 1; fi", "/bin/bash -c \"if [[ ! \\\"$LETSENCRYPT_ACCOUNT_EMAIL\\\" =~ ([^@]+)@([^\\.]+) ]]; then echo \\\"LETSENCRYPT_ACCOUNT_EMAIL is not a valid email address\\\"; exit 1; fi\""]}
Nothing was up and this was the only error..! What is happening here??? Why does it have to be this much complicated??
If I can get that subdomain in a click and done everything related with it. Can I then just change/ replace the yml setting only with new hostname, smtp, and email … etc?? Would it work and site will be up and running once app rebuilt??? I’m guessing yes, but need to ask an expert to believe
