Error al iniciar con "postgres ya en ejecución"
This morning I tried to turn a plugin back on (moderator plugin) and got the following error when rebuilding the app. I then disabled the plugin and rebuilt again to only get the same error. I also tried disabling all the plugins. Any other ideas? This is on my sandbox so it’s not critical. It was working fine prior to this and I didn’t make any other changes besides a git pull.
FAILED
Pups::ExecError: socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1 failed with return #<Process::Status: pid 44 exit 1>
exec failed with the params "socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1"
740f79002f403805b363a73f114aef7a2075556ac205778eb27e2d63f2c0fe74
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Looks like it’s trying to spawn a new process when there is already one running?
Try a reboot?:
sudo shutdown -r now
1 me gusta
Silly me. Thanks merefield!
1 me gusta
Curiosity: does sudo reboot command do the same thing as sudo shutdown -r now? ( i always used reboot on linux, only used shutdown -r -t 0 in windows :D)
Suspect they do the same thing under the hood (switching run levels) but don’t quote me on it!
