Users reported a failed upgrade from Discourse 2.9.0.beta14 to 3.1.0.beta, resulting in a 500 error due to a Ruby version incompatibility. The issue stemmed from the web-push-3.0.0 gem requiring Ruby 3.0+, while the system was running Ruby 2.7.6 xyzzy. The problem was resolved by manually rebuilding the app using cd /var/discourse && git pull && ./launcher rebuild appxyzzy. This fix was confirmed by multiple users, including iidbae and Wingtip, who noted that the Docker Manager upgrade failed because it didn’t handle the Ruby version change. The discussion highlights that development environments may not accurately reflect production setups, and that manual CLI commands are necessary when automated upgrades fail Stephen.
I upgrade every month, always on a few development systems first, then production.
During this month’s cycle, the upgrade failed on the 1st development system. docker_manager upgraded fine but the discourse upgrade failed with:
Sorry, there was an error upgrading Discourse. Please check the logs below.
The Discourse app is completely down (it’s displaying the “Oops” error 500 page).
Here’s what the on-screen log contains:
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 50
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Waiting for Unicorn to reload........
Waiting for Unicorn to reload.........
Waiting for Unicorn to reload..........
Waiting for Unicorn to reload...........
Stopping 7 Unicorn worker(s), to free up memory
Stopping job queue to reclaim memory, master pid is 4069
$ cd /var/www/discourse && git fetch --tags --force && git reset --hard HEAD@{upstream}
From https://github.com/discourse/discourse
t [tag update] latest-release -> latest-release
* [new tag] v2.8.14 -> v2.8.14
* [new tag] v3.0.0 -> v3.0.0
HEAD is now at 666536cbd1 DEV: Prefer \A and \z over ^ and $ in regexes (#19936)
$ bundle install --deployment --jobs 4 --without test development
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
Bundler 2.3.13 is running, but your lockfile was generated with 2.4.1. Installing Bundler 2.4.1 and restarting using that version.
Fetching gem metadata from https://rubygems.org/.
Fetching bundler 2.4.1
Installing bundler 2.4.1
Fetching gem metadata from https://rubygems.org/.........
Fetching https://github.com/rails/sprockets
web-push-3.0.0 requires ruby version >= 3.0, which is incompatible with the
current version, 2.7.6
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:209:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:93:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-7.0.3.1/lib/active_support/fork_tracker.rb:20:in `block in fork'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-7.0.3.1/lib/active_support/fork_tracker.rb:18:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-7.0.3.1/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-7.0.3.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-7.0.3.1/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-7.0.3.1/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-7.0.3.1/lib/rails/commands.rb:18:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.15.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
bin/rails:18:in `<main>'
Spinning up 7 Unicorn worker(s) that were stopped initially
I’ve never had an upgrade error before so I’m unclear what to do next. And if this had happened in production, what would I do?
I suggest you check what version of operating system (distribution) you are running: it could be that it’s an old version, doesn’t have ruby 3, and that’s the problem.
Edit: hang on, I’m not sure if I might be confused. For production, everything happens within a Docker container which should have all the right versions of everything. Do you have some other kind of setup?
If those are development installs they won’t be representative of a production docker install. Your dev environment has an old version of ruby (2.7), whereas Discourse recently bumped up to 3.1 in the image.
Same issue here, upgrade failed and nuked the forum to 500 errors. I’m honestly rather surprised this issue persisted for 3 days so far.
Anyway I’m running a CLI rebuild now which will hopefully work. If not, I took a VM snapshot first because my momma didn’t raise no fool.
From this post it looks like they upgraded ruby to 3.0 which completely breaks web upgrades. Unfortunately the software still lets users try it, and then you get to see how quickly your host can serve up HTTP 500 errors.
Edit: The CLI rebuild did indeed work, phew!
Relevant errors:
