Le forum plante après la mise à jour depuis 2.4.0
Hi! today I upgraded the forum in a regular way (admin > dashboard > upgrade) from 2.4.0.
After that, back to the upgrades view to keep upgrading the rest of the plunging this message came up
You are running an old version of the Discourse image.
Upgrades via the web UI are disabled until you run the latest image.
To do so log in to your server using SSH and run:
    cd /var/discourse
    git pull
    ./launcher rebuild app
Nothing new until now. Opened the term, joined the virtual machine and followed those steps as always, but now I'm receiving an error I've never seen before. Here are the logs
root@foro:/var/discourse# ./launcher rebuild app
Fetching origin
Launcher is up-to-date
cd /pups && git pull && /pups/bin/pups --stdin
Already up to date.
I, [2020-07-03T17:40:38.599175 #1]  INFO -- : Loading --stdin
I, [2020-07-03T17:40:38.608573 #1]  INFO -- : > apt-get remove -y postgresql-10 postgresql-client-10 postgresql-contrib-10
I, [2020-07-03T17:40:40.109309 #1]  INFO -- : Reading package lists...
Building dependency tree...
Reading state information...
Package 'postgresql-10' is not installed, so not removed
Package 'postgresql-client-10' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I, [2020-07-03T17:40:40.110000 #1]  INFO -- : > apt-get update && apt-get install -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5
debconf: delaying package configuration, since apt-utils is not installed
I, [2020-07-03T17:40:49.742789 #1]  INFO -- : Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:2 http://apt.postgresql.org/pub/repos/apt buster-pgdg InRelease [84.6 kB]
Hit:3 http://deb.debian.org/debian buster InRelease
Get:4 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:5 https://deb.nodesource.com/node_10.x buster InRelease [4,584 B]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [208 kB]
Get:7 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 Packages [177 kB]
Get:8 http://deb.debian.org/debian buster-updates/main amd64 Packages.diff/Index [3,688 B]
Get:9 http://deb.debian.org/debian buster-updates/main amd64 Packages 2020-06-04-2016.16.pdiff [1,101 B]
Get:10 http://deb.debian.org/debian buster-updates/main amd64 Packages 2020-06-07-1403.53.pdiff [439 B]
Get:11 http://deb.debian.org/debian buster-updates/main amd64 Packages 2020-06-13-2000.26.pdiff [552 B]
Get:12 https://deb.nodesource.com/node_10.x buster/main amd64 Packages [768 B]
Fetched 599 kB in 1s (686 kB/s)
Suggested packages:
  postgresql-doc-9.5 libdbd-pg-perl
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 13 not upgraded.
Need to get 5,700 kB of archives.
After this operation, 27.2 MB of additional disk space will be used.
Get:1 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-client-9.5 amd64 9.5.22-1.pgdg100+1 [1,252 kB]
Get:2 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-9.5 amd64 9.5.22-1.pgdg100+1 [3,985 kB]
Get:3 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-contrib-9.5 amd64 9.5.22-1.pgdg100+1 [463 kB]
Fetched 5,700 kB in 0s (27.1 MB/s)
Selecting previously unselected package postgresql-client-9.5.
(Reading database ... 43929 files and directories currently installed.)
Preparing to unpack .../postgresql-client-9.5_9.5.22-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-client-9.5 (9.5.22-1.pgdg100+1) ...
Selecting previously unselected package postgresql-9.5.
Preparing to unpack .../postgresql-9.5_9.5.22-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-9.5 (9.5.22-1.pgdg100+1) ...
Selecting previously unselected package postgresql-contrib-9.5.
Preparing to unpack .../postgresql-contrib-9.5_9.5.22-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-contrib-9.5 (9.5.22-1.pgdg100+1) ...
Setting up postgresql-client-9.5 (9.5.22-1.pgdg100+1) ...
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/12/man/man1/psql.1.gz because link group psql.1.gz is broken
Setting up postgresql-9.5 (9.5.22-1.pgdg100+1) ...
Creating new PostgreSQL cluster 9.5/main ...
/usr/lib/postgresql/9.5/bin/initdb -D /var/lib/postgresql/9.5/main --auth-local peer --auth-host md5
The files belonging to this database system will be owned by user "postgres".
This user must also own the server process.
The database cluster will be initialized with locale "C.UTF-8".
The default database encoding has accordingly been set to "UTF8".
The default text search configuration will be set to "english".
Data page checksums are disabled.
fixing permissions on existing directory /var/lib/postgresql/9.5/main ... ok
creating subdirectories ... ok
selecting default max_connections ... 100
selecting default shared_buffers ... 128MB
selecting default timezone ... Etc/UTC
selecting dynamic shared memory implementation ... posix
creating configuration files ... ok
creating template1 database in /var/lib/postgresql/9.5/main/base/1 ... ok
initializing pg_authid ... ok
initializing dependencies ... ok
creating system views ... ok
loading system objects' descriptions ... ok
creating collations ... ok
creating conversions ... ok
creating dictionaries ... ok
setting privileges on built-in objects ... ok
creating information schema ... ok
loading PL/pgSQL server-side language ... ok
vacuuming database template1 ... ok
copying template1 to template0 ... ok
copying template1 to postgres ... ok
syncing data to disk ... ok
Success. You can now start the database server using:
    /usr/lib/postgresql/9.5/bin/pg_ctl -D /var/lib/postgresql/9.5/main -l logfile start
Ver Cluster Port Status Owner    Data directory               Log file
9.5 main    5433 down   postgres /var/lib/postgresql/9.5/main /var/log/postgresql/postgresql-9.5-main.log
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/12/man/man1/postmaster.1.gz because link group postmaster.1.gz is broken
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Setting up postgresql-contrib-9.5 (9.5.22-1.pgdg100+1) ...
Processing triggers for postgresql-common (213.pgdg100+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
I, [2020-07-03T17:40:49.743707 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2020-07-03T17:40:49.747572 #1]  INFO -- :
I, [2020-07-03T17:40:49.748032 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-07-03T17:40:49.750621 #1]  INFO -- :
I, [2020-07-03T17:40:49.751119 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2020-07-03T17:40:49.753527 #1]  INFO -- :
I, [2020-07-03T17:40:49.753870 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2020-07-03T17:40:49.756586 #1]  INFO -- :
I, [2020-07-03T17:40:49.756966 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-07-03T17:40:49.759345 #1]  INFO -- :
I, [2020-07-03T17:40:49.759525 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/07/03 17:40:49 socat[1570] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2020-07-03T17:40:49.764619 #1]  INFO -- :
I, [2020-07-03T17:40:49.764790 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-07-03T17:40:49.768012 #1]  INFO -- :
I, [2020-07-03T17:40:49.768201 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-07-03T17:40:49.771186 #1]  INFO -- :
I, [2020-07-03T17:40:49.771329 #1]  INFO -- : > mkdir -p /shared/postgres_run/9.5-main.pg_stat_tmp
I, [2020-07-03T17:40:49.773782 #1]  INFO -- :
I, [2020-07-03T17:40:49.774066 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/9.5-main.pg_stat_tmp
I, [2020-07-03T17:40:49.776490 #1]  INFO -- :
I, [2020-07-03T17:40:49.782041 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2020-07-03T17:40:49.788039 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2020-07-03T17:40:49.788568 #1]  INFO -- : > chown -R root /var/lib/postgresql/9.5/main
I, [2020-07-03T17:40:49.799608 #1]  INFO -- :
I, [2020-07-03T17:40:49.799833 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/9.5/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-07-03T17:40:49.802712 #1]  INFO -- :
I, [2020-07-03T17:40:49.802859 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-07-03T17:40:49.823259 #1]  INFO -- :
I, [2020-07-03T17:40:49.823552 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-07-03T17:40:49.827629 #1]  INFO -- :
I, [2020-07-03T17:40:49.828112 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/9.5/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.828954 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.829559 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.830168 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.830753 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.831385 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.831981 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2020-07-03T17:40:49.835928 #1]  INFO -- :
I, [2020-07-03T17:40:49.836456 #1]  INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = $db_max_wal_senders in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.837120 #1]  INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = $db_wal_level in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.837800 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.838367 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.838967 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/9.5/main/postgresql.conf
I, [2020-07-03T17:40:49.839599 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/9.5/main/pg_hba.conf
I, [2020-07-03T17:40:49.840164 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/9.5/main/pg_hba.conf
I, [2020-07-03T17:40:49.840674 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main
I, [2020-07-03T17:40:49.843014 #1]  INFO -- : > sleep 5
2020-07-03 17:40:49.929 UTC [1589] LOG:  database system was shut down at 2020-07-03 17:35:44 UTC
2020-07-03 17:40:49.935 UTC [1589] LOG:  MultiXact member wraparound protections are now enabled
2020-07-03 17:40:49.939 UTC [1593] LOG:  autovacuum launcher started
2020-07-03 17:40:49.939 UTC [1586] LOG:  database system is ready to accept connections
I, [2020-07-03T17:40:54.846567 #1]  INFO -- :
I, [2020-07-03T17:40:54.847806 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
createdb: error: could not connect to database template1: could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
I, [2020-07-03T17:40:54.926943 #1]  INFO -- :
I, [2020-07-03T17:40:54.927231 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
psql: error: could not connect to server: could not connect to server: No such file or directory
I, [2020-07-03T17:40:55.015051 #1]  INFO -- :
I, [2020-07-03T17:40:55.015594 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2020-07-03T17:40:55.091507 #1]  INFO -- :
I, [2020-07-03T17:40:55.091839 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2020-07-03T17:40:55.167810 #1]  INFO -- :
I, [2020-07-03T17:40:55.168235 #1]  INFO -- : Terminating async processes
I, [2020-07-03T17:40:55.168298 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 1586
2020-07-03 17:40:55.168 UTC [1586] LOG:  received fast shutdown request
2020-07-03 17:40:55.168 UTC [1586] LOG:  aborting any active transactions
2020-07-03 17:40:55.170 UTC [1593] LOG:  autovacuum launcher shutting down
2020-07-03 17:40:55.172 UTC [1590] LOG:  shutting down
2020-07-03 17:40:55.189 UTC [1590] LOG:  database system is shut down
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 1618 exit 2>
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
a10b0d1db8256d70432e08508f453835a4bd7dce8f4ac601b6be1031bb3ce01b
After trying all the classic tricks (including “turn it off and on again”), I’m a little bit lost here. I don’t understand why it can access to the DB :frowning:
1 « J'aime »
PostgreSQL 9.5 ?! Mais c’est très ancien.
Pourriez-vous s’il vous plaît copier et coller ici les premières lignes du fichier /var/discourse/containers/app.yml ?
3 « J'aime »
Hola! thanks for answering!
root@foro:/var/discourse# cat /var/discourse/containers/app.yml
## After making changes to this file, you MUST rebuild for any changes
## to take effect in your live Discourse instance:
## Make sure to obey YAML syntax! You can use this site to help check:
## http://www.yamllint.com/
## this is the all-in-one, standalone Discourse Docker container template
# You may add rate limiting by uncommenting the web.ratelimited template.
# Out of the box it allows 12 reqs a second per ip, and 100 per minute per ip
# This is configurable by amending the params in this file
templates:
  # - "templates/postgres.template.yml"
  - "templates/postgres.9.5.template.yml"
 ## Comment out the following lines if you wish to add Lets Encrypt for your Discourse install
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
I just tried with “templates/postgres.10.template.yml” (as I just read here) but still throwing errors:
Already up to date.
I, [2020-07-03T17:50:57.037855 #1]  INFO -- : Loading --stdin
I, [2020-07-03T17:50:57.050344 #1]  INFO -- : > DEBIAN_FRONTEND=noninteractive apt-get purge -y postgresql-12 postgresql-client-12 postgresql-contrib-12
I, [2020-07-03T17:50:59.618428 #1]  INFO -- : Reading package lists...
The following package was automatically installed and is no longer required:
  libllvm7
Use 'apt autoremove' to remove it.
The following packages will be REMOVED:
  postgresql-12* postgresql-client-12*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 52.8 MB disk space will be freed.
Removing postgresql-12 (12.2-2.pgdg100+1) ...
invoke-rc.d: policy-rc.d denied execution of stop.
Removing postgresql-client-12 (12.2-2.pgdg100+1) ...
(Reading database ... 42106 files and directories currently installed.)
Purging configuration files for postgresql-12 (12.2-2.pgdg100+1) ...
Dropping cluster main...
I, [2020-07-03T17:50:59.618701 #1]  INFO -- : > apt-get update && apt-get install -y postgresql-10 postgresql-client-10 postgresql-contrib-10
I, [2020-07-03T17:51:08.574737 #1]  INFO -- : Hit:1 http://deb.debian.org/debian buster InRelease
Get:2 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:3 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:4 https://deb.nodesource.com/node_10.x buster InRelease [4,584 B]
Get:5 http://apt.postgresql.org/pub/repos/apt buster-pgdg InRelease [84.6 kB]
Get:7 http://deb.debian.org/debian buster-updates/main amd64 Packages.diff/Index [3,688 B]
Get:8 http://deb.debian.org/debian buster-updates/main amd64 Packages 2020-06-04-2016.16.pdiff [1,101 B]
Get:9 http://deb.debian.org/debian buster-updates/main amd64 Packages 2020-06-07-1403.53.pdiff [439 B]
Get:10 http://deb.debian.org/debian buster-updates/main amd64 Packages 2020-06-13-2000.26.pdiff [552 B]
Get:11 https://deb.nodesource.com/node_10.x buster/main amd64 Packages [768 B]
Get:12 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 Packages [177 kB]
Fetched 599 kB in 1s (616 kB/s)
  libllvm7
Suggested packages:
  postgresql-doc-10
0 upgraded, 2 newly installed, 0 to remove and 11 not upgraded.
Need to get 6,390 kB of archives.
After this operation, 30.6 MB of additional disk space will be used.
Get:1 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-client-10 amd64 10.13-1.pgdg100+1 [1,428 kB]
Get:2 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-10 amd64 10.13-1.pgdg100+1 [4,961 kB]
Fetched 6,390 kB in 0s (28.3 MB/s)
Selecting previously unselected package postgresql-client-10.
Preparing to unpack .../postgresql-client-10_10.13-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-client-10 (10.13-1.pgdg100+1) ...
Selecting previously unselected package postgresql-10.
Preparing to unpack .../postgresql-10_10.13-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-10 (10.13-1.pgdg100+1) ...
Setting up postgresql-client-10 (10.13-1.pgdg100+1) ...
update-alternatives: using /usr/share/postgresql/10/man/man1/psql.1.gz to provide /usr/share/man/man1/psql.1.gz (psql.1.gz) in auto mode
Setting up postgresql-10 (10.13-1.pgdg100+1) ...
Creating new PostgreSQL cluster 10/main ...
/usr/lib/postgresql/10/bin/initdb -D /var/lib/postgresql/10/main --auth-local peer --auth-host md5
fixing permissions on existing directory /var/lib/postgresql/10/main ... ok
running bootstrap script ... ok
performing post-bootstrap initialization ... ok
    pg_ctlcluster 10 main start
10  main    5432 down   postgres /var/lib/postgresql/10/main /var/log/postgresql/postgresql-10-main.log
update-alternatives: using /usr/share/postgresql/10/man/man1/postmaster.1.gz to provide /usr/share/man/man1/postmaster.1.gz (postmaster.1.gz) in auto mode
I, [2020-07-03T17:51:08.576309 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2020-07-03T17:51:08.579856 #1]  INFO -- :
I, [2020-07-03T17:51:08.580190 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-07-03T17:51:08.582830 #1]  INFO -- :
I, [2020-07-03T17:51:08.583011 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2020-07-03T17:51:08.585062 #1]  INFO -- :
I, [2020-07-03T17:51:08.585264 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2020-07-03T17:51:08.587809 #1]  INFO -- :
I, [2020-07-03T17:51:08.588006 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-07-03T17:51:08.590249 #1]  INFO -- :
I, [2020-07-03T17:51:08.590442 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/07/03 17:51:08 socat[1560] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2020-07-03T17:51:08.596137 #1]  INFO -- :
I, [2020-07-03T17:51:08.596439 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-07-03T17:51:08.600217 #1]  INFO -- :
I, [2020-07-03T17:51:08.600879 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-07-03T17:51:08.604747 #1]  INFO -- :
I, [2020-07-03T17:51:08.604982 #1]  INFO -- : > mkdir -p /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-07-03T17:51:08.608774 #1]  INFO -- :
I, [2020-07-03T17:51:08.609388 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-07-03T17:51:08.613026 #1]  INFO -- :
I, [2020-07-03T17:51:08.621472 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2020-07-03T17:51:08.628392 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2020-07-03T17:51:08.628991 #1]  INFO -- : > chown -R root /var/lib/postgresql/10/main
I, [2020-07-03T17:51:08.639852 #1]  INFO -- :
I, [2020-07-03T17:51:08.640419 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/10/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-07-03T17:51:08.642774 #1]  INFO -- :
I, [2020-07-03T17:51:08.642909 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-07-03T17:51:08.662272 #1]  INFO -- :
I, [2020-07-03T17:51:08.662970 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-07-03T17:51:08.666112 #1]  INFO -- :
I, [2020-07-03T17:51:08.666551 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/10/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.667306 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.667901 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.668472 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.668961 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.669431 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.669849 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2020-07-03T17:51:08.674201 #1]  INFO -- :
I, [2020-07-03T17:51:08.674855 #1]  INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = $db_max_wal_senders in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.675531 #1]  INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = $db_wal_level in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.676111 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.676715 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.677378 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/10/main/postgresql.conf
I, [2020-07-03T17:51:08.678065 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/10/main/pg_hba.conf
I, [2020-07-03T17:51:08.678642 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/10/main/pg_hba.conf
I, [2020-07-03T17:51:08.679176 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main
I, [2020-07-03T17:51:08.681526 #1]  INFO -- : > sleep 5
2020-07-03 17:51:08.696 UTC [1576] FATAL:  database files are incompatible with server
2020-07-03 17:51:08.696 UTC [1576] DETAIL:  The data directory was initialized by PostgreSQL version 9.5, which is not compatible with this version 10.13 (Debian 10.13-1.pgdg100+1).
I, [2020-07-03T17:51:13.684752 #1]  INFO -- :
I, [2020-07-03T17:51:13.685864 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
createdb: could not connect to database template1: could not connect to server: No such file or directory
I, [2020-07-03T17:51:13.767307 #1]  INFO -- :
I, [2020-07-03T17:51:13.767716 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
psql: could not connect to server: No such file or directory
I, [2020-07-03T17:51:13.851212 #1]  INFO -- :
I, [2020-07-03T17:51:13.851495 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2020-07-03T17:51:13.928923 #1]  INFO -- :
I, [2020-07-03T17:51:13.929167 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2020-07-03T17:51:14.007486 #1]  INFO -- :
I, [2020-07-03T17:51:14.007988 #1]  INFO -- : Terminating async processes
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 1602 exit 2>
2941a508509ae0342bb77af4711f0e0a38436095cd1468d01cbe16aba7c3fc41
3 « J'aime »
Pourriez-vous essayer avec templates/postgres.template.yml à la place ?
4 « J'aime »
Bien sûr, voici les journaux pour celui-ci :
Vérification que le lanceur est à jour
Récupération de l'origine
Le lanceur est à jour
Déjà à jour.
I, [2020-07-03T17:53:22.625663 #1]  INFO -- : Chargement de --stdin
I, [2020-07-03T17:53:22.635149 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2020-07-03T17:53:22.671728 #1]  INFO -- : Génération des paramètres régionaux (cela peut prendre un certain temps)...
Génération terminée.
I, [2020-07-03T17:53:22.672429 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2020-07-03T17:53:22.677925 #1]  INFO -- :
I, [2020-07-03T17:53:22.678274 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-07-03T17:53:22.681699 #1]  INFO -- :
I, [2020-07-03T17:53:22.681920 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2020-07-03T17:53:22.684258 #1]  INFO -- :
I, [2020-07-03T17:53:22.684487 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2020-07-03T17:53:22.687048 #1]  INFO -- :
I, [2020-07-03T17:53:22.687247 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-07-03T17:53:22.689561 #1]  INFO -- :
I, [2020-07-03T17:53:22.689885 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres déjà en cours d'exécution, arrêter le conteneur ; exit 1
2020/07/03 17:53:22 socat[26] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36) : Aucun fichier ou répertoire de ce type
I, [2020-07-03T17:53:22.694785 #1]  INFO -- :
I, [2020-07-03T17:53:22.695006 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-07-03T17:53:22.698248 #1]  INFO -- :
I, [2020-07-03T17:53:22.698408 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-07-03T17:53:22.701558 #1]  INFO -- :
I, [2020-07-03T17:53:22.701719 #1]  INFO -- : > mkdir -p /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-07-03T17:53:22.704625 #1]  INFO -- :
I, [2020-07-03T17:53:22.704807 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-07-03T17:53:22.707685 #1]  INFO -- :
I, [2020-07-03T17:53:22.713135 #1]  INFO -- : Fichier > /etc/service/postgres/run  chmod: +x  chown:
I, [2020-07-03T17:53:22.718045 #1]  INFO -- : Fichier > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2020-07-03T17:53:22.723816 #1]  INFO -- : Fichier > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2020-07-03T17:53:22.730016 #1]  INFO -- : Fichier > /root/upgrade_postgres  chmod: +x  chown:
I, [2020-07-03T17:53:22.730328 #1]  INFO -- : > chown -R root /var/lib/postgresql/12/main
I, [2020-07-03T17:53:22.862955 #1]  INFO -- :
I, [2020-07-03T17:53:22.863371 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/12/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-07-03T17:53:22.866954 #1]  INFO -- :
I, [2020-07-03T17:53:22.867304 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-07-03T17:53:22.887517 #1]  INFO -- :
I, [2020-07-03T17:53:22.887828 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-07-03T17:53:22.891051 #1]  INFO -- :
I, [2020-07-03T17:53:22.891375 #1]  INFO -- : > /root/upgrade_postgres
I, [2020-07-03T17:53:22.919256 #1]  INFO -- : Mise à niveau de PostgreSQL de la version 9.5 vers 12
AVERTISSEMENT : La mise à niveau de PostgreSQL nécessiterait 53 Go supplémentaires d'espace disque
Veuillez libérer de l'espace ou étendre votre disque avant de continuer.
Pour éviter la mise à niveau, remplacez "templates/postgres.template.yml" par "templates/postgres.10.template.yml" dans containers/app.yml
ÉCHEC
Pups::ExecError : /root/upgrade_postgres a échoué avec le code de retour #<Process::Status: pid 45 exit 1>
Emplacement de l'échec : /pups/lib/pups/exec_command.rb:112:in `spawn'
Échec de l'exécution avec les paramètres "/root/upgrade_postgres"
584f999e4af2664cac606c4f56491e458a4f40913dc2f0f4c595792854c33fae
** ÉCHEC DU BOOTSTRAP ** veuillez faire défiler vers le haut et rechercher les messages d'erreur antérieurs, il peut y en avoir plus d'un.
./discourse-doctor peut aider à diagnostiquer le problème.
2 « J'aime »
@Falco, un instant :thinking:
AVERTISSEMENT : La mise à niveau de PostgreSQL nécessiterait 53 Go d’espace disque supplémentaire
peut-être que tous les problèmes sont liés à l’espace disque !? :thinking:
3 « J'aime »
Maintenant que vous utilisez notre modèle PostgreSQL le plus récent et pris en charge, c’est effectivement le cas.
Notre script demande un espace libre équivalent à deux fois la taille actuelle de la base de données. Il semble que vous ayez une instance assez volumineuse !
4 « J'aime »
Un forum vieux de 3 ans avec beaucoup d’activité :sweat_smile: J’agrandis l’espace sur DigitalOcean (cela prend un peu de temps), je reviendrai plus tard mettre à jour mon premier message si cela s’avère être la solution.
Merci beaucoup @Falco, je perdais la tête face à ce problème, et parler à quelqu’un d’autre m’a beaucoup aidé :joy:
3 « J'aime »
Il vaudrait peut-être mieux créer une nouvelle gouttelette avec un système d’exploitation mis à jour et restaurer les données sur cette nouvelle instance.
Cela vous donnera un nouveau système d’exploitation, ne nécessitera pas autant d’espace disque et entraînera moins de temps d’arrêt : vous mettriez simplement l’ancien site en mode lecture seule pendant la sauvegarde/restauration vers la nouvelle gouttelette, puis vous basculeriez le DNS. Vous pourriez utiliser une adresse IP statique (je ne me souviens plus du terme exact) pour effectuer le basculement au niveau du réseau plutôt qu’au niveau du DNS (après avoir pointé le DNS vers l’adresse IP statique).
2 « J'aime »
@Falco confirmé : modifier le modèle et étendre l’espace disque fonctionne à merveille. Merci !
@pfaffman c’est une excellente idée, je vais essayer de le faire ce week-end. Merci pour les suggestions.
5 « J'aime »
