From _t cookie how to get the current user id?
I am trying to develop an app using the same DB as discourse.
Discourse is run from:
www.example.com/forums/
The app is run from:
www.example.com/app/
Inside /app/ app on server side I have access to _t token.
From the _t token how do I get the user id by querying the Postgres DB.
I know I can use SSO but that requires making a request to the client side. So I want to keep things simple and get the logged in user’s identity by just querying the postgres DB directly from inside the app running at www.example.com/app/
In postgres table user_auth_tokens the field auth_tokens has the value “Gzfb6AV4VkGvumpIm54u6hxdBuU”
In the cookie _t the value is 35d802b49d5565441aedf58410064505
From “35d802b49d5565441aedf58410064505” how do I derive “Gzfb6AV4VkGvumpIm54u6hxdBuU” ?
I have the following hypothesis:
  1. In the DB table user_auth_tokens the field auth_tokens is storing the hashed value of the cookie _t.
  2. The hashing is being done by discourse/app/models/user_auth_token.rb at c68999e1283ea7f9bc50fe6e8df3c4ddc05b7df0 · discourse/discourse · GitHub
Digest::SHA1.base64digest(“#{token}#{GlobalSetting.safe_secret_key_base}”)
  1. To get the value of GlobalSetting.safe_secret_key_base from redis I will get the value of SECRET_TOKEN
127.0.0.1:6379> get SECRET_TOKEN
“eadc1240dfa7cccc5801e82f1b302913a91604a0d97dcc1fb7b44d8275037904fa517710d29059e53251f5bf46ebbe16d0686226a6bc5032bbafcc987a2bd30b”
ref: discourse/app/models/global_setting.rb at a1ee61ec25d8de128faf46d765d1aeda9d880654 · discourse/discourse · GitHub
Are my hypothesis correct?
When I do sha1 for
35d802b49d5565441aedf58410064505eadc1240dfa7cccc5801e82f1b302913a91604a0d97dcc1fb7b44d8275037904fa517710d29059e53251f5bf46ebbe16d0686226a6bc5032bbafcc987a2bd30b
I get
1b37dbe805785641afba6a489b9e2eea1c5d06e5
And base64digest for 1b37dbe805785641afba6a489b9e2eea1c5d06e5 is: MWIzN2RiZTgwNTc4NTY0MWFmYmE2YTQ4OWI5ZTJlZWExYzVkMDZlNQ==
Why is it not matching the value stored in the table user_auth_tokens the field auth_tokens?
Putting aside the part where this is a Bad Idea™ because eventually Discourse will update and this will break…
Are you sure you did that last step correctly? https://play.golang.org/p/6bWfZ8uDX5
Thank you. it works!!
