GCODE-Hervorhebung ist standardmäßig nicht enthalten
Hi,
Trouble
.gcode highlighting is confused, even though gcode is a supported language in highlight.js.
A simple test
auto language selection (maybe some sort of C? )
M117 Heating Up ; write heating up
M190 S30 ; heat up the bed to 30°C and hold
ruby specified (yay. this is to show that forced language selection does something)
gcode specified (nay, it looks like the auto-select, and it ain’t right.)
thus
Is there some test I can do to see whether this is on Discourse side or Highlight.js side?
(And then, what would that mean…)
highlight.js supports a very large number of languages. It would result in very poor performance if we supported all languages by default. gcode is not a default language supported, so it will not work here on Meta. You can add support for gcode on your site by adding it to the highlighted languages site setting.
For reference, here are the languages supported on Meta:
Thanks for a swift reply.
After I enabled gcode, the highlighting is still funky/ funky in a completely new way, but now it looks like highlight.js issue. I guess the gcode support is just… not working. Still better than before! just can’t handle gcode comments it seems.
Thanks!
That you’d need to take up with highlight.js. Glad you got it working!
