I am getting error 422 invalid argument when using s3 upload with GCS , can’t seems to find any clue or detail error log. Only log i got is
{failed: “FAILED”, message: “Invalid argument.”}
failed: “FAILED”
my configured setting is as below
if possible where can i view the detailed error log
sam
(Sam Saffron)
Perhaps try YOURSITE/logs
It’s a tough one, we only really support AWS S3, GCS is a best community effort kind of thing.
is it possible to remove all hard code log exclude pattern in logster ? i can’t view any log with error 422
i believe there should be error return from GCS api but discourse app is suppressing it
pfaffman
(Jay Pfaffman)
4
You need to follow the advice in Configure an S3 compatible object storage provider for uploads. Configuring s3 in the UX isn’t really recommended.
