Hello,
I am trying to setup Lets Encrypt SSL, so while installing discourse, I tried setting the email for Lets encrypt but I got below error :-
Checking your domain name . . . WARNING:: This server does not appear to be accessible at domainex.com:443. A connection to http://domainex.com (port 80) also fails. This suggests that domainex.com resolves to the wrong IP address or that traffic is not being routed to your server. Google: “open ports YOUR CLOUD SERVICE” for information for resolving this problem. You should probably answer “n” at the next prompt and disable Let’s Encrypt. This test might not work for all situations, so if you can access Discourse at http://domainex.com, you might try anyway.
The above is the error message from discourse install, there might be anything missing in my GCP config.
I installed without SSL now but can anyone tell me what might be the issue
Is it the case that your DNS does point to your server and the ports are open?and you can access discourse with your hostname? If so, you can ignore those warnings
And see what happens. I don’t know under what conditions the test the script does might fail to connect to itself, but there could be some.
Hi pfaffman,
I am able to access my domain and see the Congratulations page on discourse in http scenario, only thing is I get Error host not found if I try to access the account activate link. But this is a different issue.
Now regarding the original issue, I pasted the exact message from discourse install. I updated my first message so that it is better disguised. Sorry for confusion, but the above error mentioned in first post only appears if I try to setup Lets Encrypt email in discourse install. I am currently not having SSL certificate installed, so do you think that might be the problem ?
