Serverfehler beim Überprüfen aller Themen
Hallo zusammen,
in unserer Discourse-Instanz für das three.js-Projekt treten kürzlich Serverfehler auf, wenn auf Review > View All geklickt wird. Der Fehler wird im Abschnitt /logs angezeigt:
Message (88-mal gemeldet)
NoMethodError (undefined method `gsub!' for nil:NilClass)
app/serializers/reviewable_score_serializer.rb:64:in `linkify_backticks'
app/serializers/reviewable_score_serializer.rb:34:in `reason'
app/serializers/reviewable_score_serializer.rb:41:in `include_reason?'
(eval):7:in `_fast_attributes'
lib/freedom_patches/ams_include_without_root.rb:54:in `include!'
app/controllers/reviewables_controller.rb:54:in `block in index'
app/controllers/reviewables_controller.rb:47:in `map!'
app/controllers/reviewables_controller.rb:47:in `index'
app/controllers/application_controller.rb:397:in `block in with_resolved_locale'
app/controllers/application_controller.rb:397:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:355:in `call'
config/initializers/008-rack-cors.rb:25:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:187:in `call'
Backtrace
active_model_serializers (0.8.4) lib/active_model/serializer.rb:375:in `include?'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:448:in `block in merge_association'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:445:in `each'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:445:in `merge_association'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:368:in `block in include_associations!'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:367:in `each_key'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:367:in `include_associations!'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:362:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:347:in `as_json'
actionpack (6.1.4.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.1.4.1) lib/abstract_controller/base.rb:228:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.1.4.1) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:117:in `block in run_callbacks'
i18n (1.8.10) lib/i18n.rb:314:in `with_locale'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:126:in `block in run_callbacks'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:137:in `run_callbacks'
actionpack (6.1.4.1) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
activesupport (6.1.4.1) lib/active_support/notifications.rb:203:in `block in instrument'
activesupport (6.1.4.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.1.4.1) lib/active_support/notifications.rb:203:in `instrument'
actionpack (6.1.4.1) lib/action_controller/metal/instrumentation.rb:33:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
activerecord (6.1.4.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.1.4.1) lib/abstract_controller/base.rb:165:in `process'
actionview (6.1.4.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.3.3) lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack (6.1.4.1) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.1.4.1) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:842:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
actionpack (6.1.4.1) lib/action_dispatch/http/permissions_policy.rb:22:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:98:in `run_callbacks'
actionpack (6.1.4.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.9.7) lib/logster/middleware/reporter.rb:43:in `call'
lograge (0.11.2) lib/lograge/rails_ext/rack/logger.rb:15:in `call_app'
railties (6.1.4.1) lib/rails/rack/logger.rb:28:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/host_authorization.rb:92:in `call'
plugins/discourse-prometheus/lib/middleware/metrics.rb:17:in `call'
rack-mini-profiler (2.3.3) lib/mini_profiler/profiler.rb:249:in `call'
message_bus (3.3.6) lib/message_bus/rack/middleware.rb:61:in `call'
rails_failover (0.7.3) lib/rails_failover/active_record/middleware.rb:69:in `block in call'
activerecord (6.1.4.1) lib/active_record/connection_handling.rb:383:in `block (2 levels) in with_role_and_shard'
activerecord (6.1.4.1) lib/active_record/connection_adapters/abstract/connection_pool.rb:1025:in `while_preventing_writes'
activerecord (6.1.4.1) lib/active_record/connection_handling.rb:381:in `block in with_role_and_shard'
activerecord (6.1.4.1) lib/active_record/connection_handling.rb:398:in `swap_connection_handler'
activerecord (6.1.4.1) lib/active_record/connection_handling.rb:373:in `with_handler'
activerecord (6.1.4.1) lib/active_record/connection_handling.rb:380:in `with_role_and_shard'
activerecord (6.1.4.1) lib/active_record/connection_handling.rb:175:in `connected_to'
rails_failover (0.7.3) lib/rails_failover/active_record/middleware.rb:66:in `call'
rails_multisite (3.1.0) lib/rails_multisite/middleware.rb:25:in `call'
railties (6.1.4.1) lib/rails/engine.rb:539:in `call'
railties (6.1.4.1) lib/rails/railtie.rb:207:in `public_send'
railties (6.1.4.1) lib/rails/railtie.rb:207:in `method_missing'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.3) lib/rack/urlmap.rb:58:in `each'
rack (2.2.3) lib/rack/urlmap.rb:58:in `call'
unicorn (6.0.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.0.0) lib/unicorn/http_server.rb:732:in `worker_loop'
unicorn (6.0.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.0.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.0.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/2.7.0/bin/unicorn:23:in `load'
vendor/bundle/ruby/2.7.0/bin/unicorn:23:in `<main>'
Env
hostname	standard17-b073c643-18e6-0ab9-2ea9-7e2187266e07, 4 weitere
process_id	241
application_version	724c836ffac6a5fd8d5210d2451126b3ce426284
HTTP_HOST	discourse.threejs.org
REQUEST_URI	/review?priority=low&status=pending&sort_order=score
REQUEST_METHOD	GET
HTTP_USER_AGENT	Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.81 Safari/537.36
HTTP_ACCEPT	application/json, text/javascript, */*; q=0.01
HTTP_REFERER	https://discourse.threejs.org/review/topics
HTTP_X_FORWARDED_FOR	217.81.31.84
HTTP_X_REAL_IP	217.81.31.84
username	Mugen87
time	10:05 Uhr
params
priority	low
status	pending
sort_order	score
Hat jemand eine Idee, wie dieses Problem gelöst werden kann?
1 „Gefällt mir“
Sieht nach einem Fehler auf unserer Seite aus, wir werden ihn in den nächsten zwei Tagen behoben haben.
2 „Gefällt mir“
Hallo @Mugen87 :wave:
Danke, dass du uns auf diesen Fehler aufmerksam gemacht hast. Ich habe bereits eine Korrektur veröffentlicht, sodass es auf deiner Seite jetzt funktionieren sollte.
3 „Gefällt mir“
