When a user selects ‘GitHub’ as the auth provider for logging in, and they have multiple email addresses in their GitHub profile, are all of those addresses provided to Discourse (or only the primary address)? If all the addresses are provided, does Discourse then search for an account matching any one of them?
When a user logs in to Discourse with their GitHub account, which has multiple email addresses, only the primary (public) email address is used for authentication. Discourse then searches for an account matching this email address, respecting email whitelists and blacklists. kpfleming is concerned about a specific scenario where a user creates an account using a custom authenticator with an email address from a blacklisted domain, then attempts to log in with GitHub using the same email address. According to sam, the desired behavior should work as the GitHubAuthenticator should reject the login if any address provided by GitHub is in a blacklist domain.
I’m pretty sure that it uses only the one listed as ‘public email’.
Yes that is how it works, we even respect email whitelists and blacklists
https://github.com/discourse/discourse/commit/2ae7c47a3ccd0412db3eddb7f99d3a2e9e0e119e
OK, so here’s my situation: I have a blacklist with one domain on it, but we also have a custom authenticator plugin which is allowed to authenticate users with addresses in that domain. What I want to avoid is a user creating an account using an address from the special domain (using our custom authenticator to do so), but then later using GitHub login with that email address as one of their addresses. I haven’t read the code in the link above, but I believe that our desired behavior should work, as GitHubAuthenticator should reject the login if any address provided by github.com is in a blacklist domain.
Hi Kevin, did you ever work this out?
