How to rewrite the template in a gjs component
frontend/discourse/app/components/search-menu.gjs
import Component from "@glimmer/component";
import { tracked } from "@glimmer/tracking";
import { concat } from "@ember/helper";
import { on } from "@ember/modifier";
import { action } from "@ember/object";
import didInsert from "@ember/render-modifiers/modifiers/did-insert";
import { cancel } from "@ember/runloop";
import { service } from "@ember/service";
import { Promise } from "rsvp";
import DButton from "discourse/components/d-button";
import MenuPanel from "discourse/components/menu-panel";
import PluginOutlet from "discourse/components/plugin-outlet";
import AdvancedButton from "discourse/components/search-menu/advanced-button";
import ClearButton from "discourse/components/search-menu/clear-button";
import Results from "discourse/components/search-menu/results";
import SearchTerm from "discourse/components/search-menu/search-term";
import concatClass from "discourse/helpers/concat-class";
import lazyHash from "discourse/helpers/lazy-hash";
import loadingSpinner from "discourse/helpers/loading-spinner";
import { popupAjaxError } from "discourse/lib/ajax-error";
import { search as searchCategoryTag } from "discourse/lib/category-tag-search";
import discourseDebounce from "discourse/lib/debounce";
import { bind } from "discourse/lib/decorators";
import getURL from "discourse/lib/get-url";
import {
  isValidSearchTerm,
  searchForTerm,
  updateRecentSearches,
} from "discourse/lib/search";
import DiscourseURL from "discourse/lib/url";
import userSearch from "discourse/lib/user-search";
import { CANCELLED_STATUS } from "discourse/modifiers/d-autocomplete";
const CATEGORY_SLUG_REGEXP = /(\#[a-zA-Z0-9\-:]*)$/gi;
const USERNAME_REGEXP = /(\@[a-zA-Z0-9\-\_]*)$/gi;
const SUGGESTIONS_REGEXP = /(in:|status:|order:|:)([a-zA-Z]*)$/gi;
export const MODIFIER_REGEXP = /.*(\#|\@|:).*$/gi;
export const DEFAULT_TYPE_FILTER = "exclude_topics";
export default class SearchMenu extends Component {
  @service search;
  @service currentUser;
  @service siteSettings;
  @service appEvents;
  @tracked loading = false;
  @tracked isPMInboxCleared = false;
  @tracked typeFilter = DEFAULT_TYPE_FILTER;
  @tracked suggestionKeyword = false;
  @tracked suggestionResults = [];
  @tracked invalidTerm = false;
  @tracked menuPanelOpen = false;
  searchInputId = this.args.searchInputId ?? "search-term";
  searchInputPlaceholder = this.args.searchInputPlaceholder || "search.title";
  _debouncer = null;
  _activeSearch = null;
  willDestroy() {
    if (!this.args.inlineResults) {
      document.removeEventListener("mousedown", this.onDocumentPress);
      document.removeEventListener("touchend", this.onDocumentPress);
    super.willDestroy(...arguments);
  @bind
  setupEventListeners() {
    // We only need to register click events when the search menu is rendered outside of the header.
    // The header handles clicking outside.
      document.addEventListener("mousedown", this.onDocumentPress);
      document.addEventListener("touchend", this.onDocumentPress);
  @bind
  onDocumentPress(event) {
    if (!this.menuPanelOpen) {
      return;
    if (!event.target.closest(".search-menu-container.menu-panel-results")) {
      this.close();
  get classNames() {
    const classes = ["search-menu-container"];
      classes.push("menu-panel-results");
    if (this.loading) {
      classes.push("loading");
    return classes.join(" ");
  get includesTopics() {
    return (
      !!this.search.results?.topics?.length ||
      this.typeFilter !== DEFAULT_TYPE_FILTER
  get searchContext() {
    if (this.search.inTopicContext || this.inPMInboxContext) {
      return this.search.searchContext;
    return false;
  get inPMInboxContext() {
    return (
      !this.isPMInboxCleared &&
      this.search.searchContext?.type === "private_messages"
  get isPMOnly() {
    // Check if search is filtered to private messages only
    const searchTerm = this.search.activeGlobalSearchTerm || "";
    return (
      this.inPMInboxContext ||
      /\bin:(personal|messages|personal-direct|all-pms)\b/i.test(searchTerm)
  @action
  onKeydown(event) {
    if (event.key === "Escape") {
      this.close();
      event.preventDefault();
      event.stopPropagation();
  @action
  close() {
    if (this.args?.onClose) {
      return this.args.onClose();
    // We want to blur the search input when in stand-alone mode
    // so that when we focus on the search input again, the menu panel pops up
    document.getElementById(this.searchInputId)?.blur();
    this.menuPanelOpen = false;
  @action
  open() {
      this.appEvents.trigger("search-menu:search_menu_opened");
    this.menuPanelOpen = true;
  @bind
  fullSearchUrl(opts) {
    let url = "/search";
    let params = new URLSearchParams();
    if (this.search.activeGlobalSearchTerm) {
      let q = this.search.activeGlobalSearchTerm;
      if (this.searchContext?.type === "topic") {
        q += ` topic:${this.searchContext.id}`;
      } else if (this.searchContext?.type === "private_messages") {
        q += " in:messages";
      params.set("q", q);
    if (opts?.expanded) {
      params.set("expanded", "true");
    if (params.toString() !== "") {
      url = `${url}?${params}`;
    return getURL(url);
  @action
  openAdvancedSearch() {
    this.fullSearch();
    this.close();
  get displayMenuPanelResults() {
    if (this.args.inlineResults) {
      return false;
    return this.menuPanelOpen;
  @bind
  clearSearch(e) {
    e.stopPropagation();
    e.preventDefault();
    this.search.activeGlobalSearchTerm = "";
    this.search.focusSearchInput();
    this.triggerSearch();
  @action
  searchTermChanged(term, opts = {}) {
    this.typeFilter = opts.searchTopics ? null : DEFAULT_TYPE_FILTER;
    if (opts.setTopicContext) {
      this.search.inTopicContext = true;
    if (opts.setPMInboxContext) {
      this.isPMInboxCleared = false;
    this.search.activeGlobalSearchTerm = term;
  @action
  fullSearch() {
    this.loading = false;
    const url = this.fullSearchUrl();
    if (url) {
      DiscourseURL.routeTo(url);
  @action
  updateTypeFilter(value) {
    this.typeFilter = value;
  @action
  clearPMInboxContext() {
    this.isPMInboxCleared = true;
  @action
  clearTopicContext() {
    this.search.inTopicContext = false;
  // for cancelling debounced search
  cancel() {
    if (this._activeSearch) {
      this._activeSearch.abort();
      this._activeSearch = null;
  async perform() {
    this.cancel();
    const matchSuggestions = this.matchesSuggestions();
    if (matchSuggestions) {
      this.search.noResults = true;
      this.search.results = {};
      this.suggestionResults = [];
      if (matchSuggestions.type === "category") {
        const categorySearchTerm = matchSuggestions.categoriesMatch[0].replace(
        const categoryTagSearch = searchCategoryTag(
          categorySearchTerm,
          this.siteSettings
        Promise.resolve(categoryTagSearch).then((results) => {
          if (results !== CANCELLED_STATUS) {
            this.suggestionResults = results;
            this.suggestionKeyword = "#";
      } else if (matchSuggestions.type === "username") {
        const userSearchTerm = matchSuggestions.usernamesMatch[0].replace(
        const opts = { includeGroups: true, limit: 6 };
        if (userSearchTerm.length > 0) {
          opts.term = userSearchTerm;
        } else {
          opts.lastSeenUsers = true;
        userSearch(opts).then((result) => {
          if (result?.users?.length > 0) {
            this.suggestionResults = result.users;
            this.suggestionKeyword = "@";
          } else {
            this.suggestionKeyword = false;
      } else {
        this.suggestionKeyword = matchSuggestions[0];
      return;
    if (!this.search.activeGlobalSearchTerm) {
      this.search.noResults = false;
      this.invalidTerm = false;
    } else if (
      !isValidSearchTerm(this.search.activeGlobalSearchTerm, this.siteSettings)
      this.invalidTerm = true;
    } else {
      this.loading = true;
      this._activeSearch = searchForTerm(this.search.activeGlobalSearchTerm, {
        typeFilter: this.typeFilter,
        fullSearchUrl: this.fullSearchUrl,
        searchContext: this.searchContext,
      this._activeSearch
          // we ensure the current search term is the one used
          // when starting the query
          if (results) {
            this.search.noResults = results.resultTypes.length === 0;
            this.search.results = results;
        .catch(popupAjaxError)
        .finally(() => {
  matchesSuggestions() {
    if (
      this.search.activeGlobalSearchTerm === undefined ||
      this.includesTopics
      return false;
    const term = this.search.activeGlobalSearchTerm.trim();
    const categoriesMatch = term.match(CATEGORY_SLUG_REGEXP);
    if (categoriesMatch) {
      return { type: "category", categoriesMatch };
    const usernamesMatch = term.match(USERNAME_REGEXP);
    if (usernamesMatch) {
      return { type: "username", usernamesMatch };
    const suggestionsMatch = term.match(SUGGESTIONS_REGEXP);
    if (suggestionsMatch) {
      return suggestionsMatch;
    return false;
  @action
  triggerSearch() {
    if (this.includesTopics) {
      if (this.search.contextType === "topic") {
        this.search.highlightTerm = this.search.activeGlobalSearchTerm;
      cancel(this._debouncer);
      this.perform();
      if (this.currentUser) {
        updateRecentSearches(
          this.currentUser,
    } else {
      if (!this.search.inTopicContext) {
        this._debouncer = discourseDebounce(this, this.perform, 400);
  <template>
    <div
      class={{this.classNames}}
      {{didInsert this.setupEventListeners}}
      {{! template-lint-disable no-invalid-interactive }}
      {{on "keydown" this.onKeydown}}
      <div class="search-input-wrapper">
        <div
          class={{concatClass
            "search-input"
            (concat "search-input--" @location)
          {{#if this.search.inTopicContext}}
            <DButton
              @icon="xmark"
              @label="search.in_this_topic"
              @title="search.in_this_topic_tooltip"
              @action={{this.clearTopicContext}}
              class="btn-default btn-small search-context"
          {{else if this.inPMInboxContext}}
            <DButton
              @icon="xmark"
              @label="search.in_messages"
              @title="search.in_messages_tooltip"
              @action={{this.clearPMInboxContext}}
          {{/if}}
          <PluginOutlet
            @name="search-menu-before-term-input"
            @outletArgs={{lazyHash openSearchMenu=this.open}}
          <SearchTerm
            @searchTermChanged={{this.searchTermChanged}}
            @typeFilter={{this.typeFilter}}
            @updateTypeFilter={{this.updateTypeFilter}}
            @triggerSearch={{this.triggerSearch}}
            @fullSearch={{this.fullSearch}}
            @clearPMInboxContext={{this.clearPMInboxContext}}
            @clearTopicContext={{this.clearTopicContext}}
            @closeSearchMenu={{this.close}}
            @openSearchMenu={{this.open}}
            @autofocus={{@autofocusInput}}
            @inputId={{this.searchInputId}}
            @inputPlaceholder={{this.searchInputPlaceholder}}
          {{#if this.loading}}
            <div class="searching">
              {{loadingSpinner}}
            </div>
          {{else}}
              <PluginOutlet @name="search-menu-before-advanced-search" />
              {{#if this.search.activeGlobalSearchTerm}}
                <ClearButton @clearSearch={{this.clearSearch}} />
              {{/if}}
              <AdvancedButton @openAdvancedSearch={{this.openAdvancedSearch}} />
            </div>
          {{/if}}
        </div>
      </div>
      {{#if @inlineResults}}
        <Results
          @searchInputId={{this.searchInputId}}
          @loading={{this.loading}}
          @invalidTerm={{this.invalidTerm}}
          @suggestionKeyword={{this.suggestionKeyword}}
          @suggestionResults={{this.suggestionResults}}
          @searchTopics={{this.includesTopics}}
          @inPMInboxContext={{this.inPMInboxContext}}
          @isPMOnly={{this.isPMOnly}}
      {{else if this.displayMenuPanelResults}}
        <MenuPanel class="search-menu-panel">
          <Results
        </MenuPanel>
      {{/if}}
    </div>
  </template>
Or to put it another way:
How does <PluginOutlet @name="search-menu-before-advanced-search" /> interact with the search-menu component in a plugin? For example, I want to access the value of the this.search instance. I tried using appEvents, but it did not work.
The outlet has no parameters, so it does not interact with the component at all.
So there’s no way to achieve interactivity now? appEvents should work, right?
