Users are experiencing issues embedding Google My Maps links in Discourse posts, which display as blank squares despite using previously functional URLs. merefield suggests adding the URL to the allowed iframes in security settings, but TheAviationGallery confirms it’s already added and still not working. scottfsmith reports the same issue even after adding to allowed frames and rebaking. PaulMw identifies the root cause: the embedded iframe uses https://www.google.com/maps/d/embed instead of viewer, which must be explicitly allowed. scottfsmith confirms this fix resolves the issue, noting the URL change was overlooked in the source code. The solution requires admins to add https://www.google.com/maps/d/embed to the allowed iframe domains in Discourse security settings.
Hello! Recently, I have been trying to embed a Google My Map link into my post on a Discourse community, and this should show up (this was embedded into a few months back)
However, when I tried embedding it into a post today (with the same link I used to embed it above, nothing changed), I was unable to do so. I have also tried this out on other discourse communities, but all I get is the below:
As you can see, it’s a blank square with nothing showing up. Is there any way to fix this?
