hoangviet
(DilysLena)
Junho 25, 2023, 2:47pm
1
Alguém já criou um modelo de Comentário Flutuante (resposta) assim?
Alguém tem uma forma de criar um formulário de Resposta sem estar logado? (como nesta imagem)
Lilly
( Lilly)
Junho 25, 2023, 3:32pm
Eu ainda não vi um composer flutuante.
Algumas solicitações semelhantes e discussões relacionadas:
Is there a theme or something to display the reply form at the bottom of threads without clicking the Reply button?
Hi,
As I understand it, a general rule of thumb is that if you want people to do more of something with software, make it easier to do.
One activity that is important for communities is making it easy for people to create posts.
I’d like to recommend a feature - perhaps it is optional - that enables a large “Start a post” composer box on the community homepage. Here’s a mockup:
[Screenshot 2023-06-17 at 4.41.02 PM]
Admins could configure a default Category for these posts. In my community,…
I’ve got a friend who used to work Facebook, and he told me that discourse should have a box at the bottom of each post to just click and start creating a reply, like Facebook and Disqus. He said it definitely makes a difference in terms of getting interaction.
If the user is not yet logged in, we could make it very easy to create an account to comment.
At the very minimum, this would be a great setting to turn on-off.
[image]
[image]
Not really, no – we want to avoid the “here’s an empty textbox, proceed to type whatever is on your mind” phenomenon that pervades the internet. Sometimes you want a little friction, and this is one of those cases. Otherwise you always get XCKD 386 . Heck, I’m considering adding a feature that won’t let you reply at all until you’ve read enough of the discussion (assuming the discussion is of reasonable length, of course).
As a theme component someone could install on their own site, have at it…
este tema incorpora uma caixa para postar tópicos.
2 curtidas
hoangviet
(DilysLena)
Junho 25, 2023, 3:42pm
3
Tema estilo Reddit,
este é um tema muito bom, eu verifiquei o tema dele.
Mas o Reddit também tem um recurso de Caixa de Resposta (aguardando) quando os usuários estão no celular. É um recurso eficaz, incentivando os usuários a Comentar. Muito necessário
