Header customization
Hello
  1. Can you place a picture to customize the entire length of the header? For instance try to make the entire image look like a real photo like leaves?
  2. How can you change the categories box to be on the landing page or customize or really create specialized landing pages like the community forum at feverbee: http//experts.feverbee.com
Have you seen this banner theme component? You could customise that to suit.
Do you mean the forum home page? That is just out of the box Discourse with customised CSS and Javascript, so yes!
As a non coder is it a hard template to adjust for?
It depends what you mean by non-coder. If you’ve never seen a line of code in your life then you will struggle. If you are a tinkerer you’ll be able to figure it out. I’d suggest having a try. You can always disable it.
