Does anyone use Discourse to house and share documents? Or is it only for online discussion?
Itâs not really designed for co-editing documents, but it makes it very easy to upload files (drag and drop), so as a place to present and talk about documents, it does quite well. You need to do some tweaks to allow file types and increase upload size.
Iâve also had clients configure other file sharing tools to automatically create Discourse topics when a new document is added.
Discourse isnât a document management system, it doesnât protect uploaded files either.
Some sites do use Discourse to manage knowledge, transferring documentation into posts, rather than simply attaching files. There are obviously added benefits here, particularly around search.
It might be easier if you told us about the problem youâre trying to solve, rather than the way youâre thinking of solving it. Someone will be able to tell you if Discourse fits your use-case and if theyâve seen similar things done elsewhere. That approach will let you tap into the shared knowledge which makes Discourse (and this community) so great.
Iâm looking for a platform that allows for discussion posts as well as a âfile library.â If someone uploads a file, is there a way to put it in a folder - ie, making the uploaded documents easy to search in the future?
This is a good point. The filenames are obfuscated, but anyone with the link can download the file.
No.[quote=âmbowzer, post:4, topic:64909â]
[/quote]
There is no way to search inside the files. If you put keywords in the topic that includes the file you can search for those words, but not inside the files themselves.
The only structure within Discourse comes from categories and tags.
You can convert your documents to markdown posts, categorise/tag them as necessary, and include links to .doc/docx files within the post, but thatâs it.
Discourse is not a document management system. It can absolutely do the above and provide you with the discussion tools around documents, but it canât manage those documents for you. That would have to happen on another system - depending on your security requirements that could be as simple as FTP, Google Drive, Office365, or may require a dedicated DMS.
And if you couldnât herd your group to using a single system for sharing documents, Discourse could be a good way to collect them all in one place.
At least for discussion, yes. As Discourse doesnât allow direct editing of uploads youâll likely end up with links to multiple versions being valid, which typically creates a lot of confusion amongst the less technical.
Basecamp has pretty good support for this. Close integration with google docs and similar.
Can any post on a discourse system be addressed by accessing the direct link? Even in a closed area?
No. Knowing the URL of a post is not enough to be able to see it. The permissions system works.
But there is a new site setting âprevent anons from downloading filesâ
What does the warning mean? Could attached Word-Documents for example not being downloaded/opened anymore?
Attached Word documents would not be downloadable for users that are not logged in.
Hello!
Apologies if this has already been answered in the thread but is there a way to upload a word document on the forum? One of my members would like to upload a word doc on a particular thread but I canât see any way to do this.
Any help on this will be much appreciated!
Thanks,
RB
Search settings for âextensionsâ and add docx.
Melanie - Did you find a platform that met your document needs? I have been searching for the same.
We;re looking at integrating Nextcloud with Discourse/NodeBB. If it works out Iâll let you know! If I remember to come back hereâŚ
What exactly do you mean by âintegratingâ here?
I use discourse and nextcloud. I have fantasies about hosting discourse and nextcloud on the same droplet, with sso and ability to see/manage discourse uploads in nextcloud.
And @tobiaseigen
I think weâre doing something more basic than that; using Nextcloud as our Document Manager and then disabling file uploads onto NodeBB (Maybe Discourse, havenât decided yet what weâre using for our website with the developer yet); but essentially having SSO between the forum and Nextcloud so that people can upload to Nextcloud and then link to the files on the forum. Itâs an extra step but will keep us much more organized.
What Tobias is talking about would be amazing; having the user being able to reference a nextcloud file in Discourse/NodeBB without switching interfaces would be pretty sweet.
If the workflow is smooth and itâs a successful innovation Iâll post a better description here. Might be 6 months plus though.
