Vorrei aggiungere etichette ai campi del modulo per creare un nuovo argomento. Esiste qualche plugin disponibile o una soluzione personalizzata?
Do you mean a template so when a user creates a new topic, there are pre-filled options just like we have on marketplace?
Can you share a mockup or screenshot of where you want these fields?
Not exactly sure what you mean, but if you want to change the placeholder text, you can do that in the admin Customization tab, under Text. Type the current placeholder of the field and you should be able to change it.
Do you mean this?: Topic Template Placeholder Text theme component
Attached is the design screenshot which i need to implement. My question was to add the labels with text field as shown in the design
So you just want to add labels for each of the fields?
Only fields labels and some styling.
There are numerous approaches here, but consider, in order of preference:
- CSS
- Use of plugin outlets
- jQuery/equivalent native javascript edits of the DOM (not sure how easy this will be because this is not a component, so I don’t think it will be that easy to schedule manipulation as there are no event hooks).
- altering the template https://github.com/discourse/discourse/blob/master/app/assets/javascripts/discourse/app/templates/composer.hbs
The last option is risky, because this file will probably get a lot of updates over time (last update was 7 days ago!) and you don’t normally want to be overriding templates, especially those that frequently change, as you will mask stuff from core too much and break things.
Ciao!
Sono interessato a fare lo stesso. La modifica del CSS nel nostro tema della community è ancora il modo consigliato per raggiungere questo obiettivo? Lavoro con un nuovo sviluppatore front-end nel mio team che posso chiedere aiuto, ma non sono sicuro di dove posso indirizzarlo nel CSS del nostro tema per aiutarlo con questo.
IMHO, se vuoi solo etichette, allora sì, quel consiglio vale. Il CSS sarebbe la prima cosa da fare.
A scopo informativo, sarebbe stato bello se l’autore originale avesse condiviso la sua soluzione dopo aver ricevuto consigli dalla community, è bello quando le persone ricambiano.
