¿Cómo pueden los miembros borrar sus propios mensajes?
My apologies if this has been discussed elsewhere (I have searched!)
Currently, members can edit but not delete their own posts.
Is there settings option I need to enable for them to be able to delete their own posts?
Under post edit time limit on the admin/site_settings/category/posting page.I see “The author can edit or delete their post for (n) minutes after posting. Set to 0 for forever.”
“min trust to edit post” is set to 0
Is there some place else I’d need to edit settings for folks to be able to delete their posts - not topics, just posts? Or is the only option to delete a post using the edit function?
Many thanks in advance!
You are incorrect. They can delete their own post. They cannot delete their own topic.
I have a feeling you are confusing the two.
Thanks for the reply, @cpradio!
Should members see a ‘delete’ option, or is deleting done via editing post?
In other words, is there some place else I’d need to edit settings for folks to be able to delete their posts - not topics, just posts? Or is the only option to delete a post using the edit function?
It is typically hidden behind the “…” on the post (I’ve expanded it on mine above)
Thanks for the speedy reply! :grinning:
OK I think what has been confusing me is it doesn’t look like a member can delete their first post - only edit it. I do see that members have the little trash can hidden behind the “…” on subsequent posts in a topic, just not on their first post if it was the first post in the topic.
Thank you so much for the help!
Según recuerdo, desde entonces hemos habilitado la opción de que los usuarios eliminen temas, con un pequeño retraso, si no tienen respuestas.
¿Cuál será el tiempo de espera?
Este tema es bastante antiguo, pero las reglas de eliminación de publicaciones de los usuarios dependen de la configuración que los administradores hayan dictado para el foro específico.
Hola @Ashwani_Kumar Si eres el administrador, estas son las configuraciones que deseas:
“primer post” == tema
