How do I extend a built-in nested route in Ember?
Mainly a question for @eviltrout
I am trying to extend some of the internal routes for the solved plugin.
I tried adding assets/javascripts/discourse/solved-route-map.js with:
export default function() {
  this.route('user', { resetNamespace: true, path: '/users/:username'} , function() {
    this.route('userActivity', { resetNamespace: true, path: 'user-activity' } , function() {
      this.route('solved');
Trouble is that it blows away the existing routes and pretty much breaks everything, I also tries with resource using the other mechanism but it does not play nice with nested routes.
Any idea how I would go about doing this?
This is not super well documented, but the route maps are actually designed just for this purpose!
You should be able to do this:
export default {
  resource: 'userActivity',
  map() {
The resource key in the object tells my custom route map code to attach the routes inside that resource.
Yeah, I tried that but it fails to map right cause it is nested :frowning: :
Okay, I got this working although it meant a 100% rewrite of how my route map worked!
https://github.com/discourse/discourse/commit/4e251eaf080cb3d77eca843a47a8a950060d2564
Using what I suggested above (with a small change) will now work:
export default {
  resource: 'user.userActivity',
  map() {
