我有一个脚本需要从 sqlite3 加载一些数据,然后将其导入到 discourse 中。
rails runner
我假设我可以在 /shared/add_in_reverse.rb 中使用类似以下的代码:
require "sqlite3"
# 打开数据库
db = SQLite3::Database.new "sqlite3.db"
k = 1234
db.execute( "SELECT * from foo where id = ?'", [ k ] ) do |row|
puts row
title = "hello there"
u = User.find_or_create_by(username: "mexample") do |user|
user.email = "me@example.com"
c = Category.find_or_create_by(name: "Something by mexample") do |category|
category.user = u
Topic.create!( title: title, category: c, user: u )
然后使用以下命令运行它:
rails r /shared/my_custom_script.rb
但是,这会失败并出现 cannot load such file -- sqlite3 (LoadError)
bundler: failed to load command: script/rails (script/rails)
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:38:in `require': cannot load such file -- sqlite3 (LoadError)
from /usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:38:in `require'
from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.17.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:17:in `require'
from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.12/lib/zeitwerk/kernel.rb:38:in `require'
Gemfile 和 bundle exec?
我记得 Ruby 有时需要使用 Gemfiles?所以我想,如果我在 /var/www/discourse 目录下,我可以加上 bundle exec 前缀。但这会失败:
# bundle exec rails r /shared/add_in_reverse.rb
fatal: detected dubious ownership in repository at '/var/www/discourse'
To add an exception for this directory, call:
git config --global --add safe.directory /var/www/discourse
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql_adapter.rb:81:in `rescue in new_client': We could not find your database: discourse. Which can be found in the database configuration file located at config/database.yml. (ActiveRecord::NoDatabaseError)
To resolve this issue:
- Did you create the database for this app, or delete it? You may need to create your database.
- Has the database name changed? Check your database.yml config has the correct database name.
IMPORT=1
好的。我看到了一些带有 IMPORT=1 的示例。我需要它吗?
IMPORT=1 rails r /shared/add_in_reverse.rb
You are trying to install in deployment mode after changing
your Gemfile. Run `bundle install` elsewhere and add the
updated Gemfile.lock to version control.
If this is a development machine, remove the /var/www/discourse/Gemfile freeze
by running `bundle config unset deployment`.
The list of sources changed
The dependencies in your gemfile changed
You have added to the Gemfile:
* mysql2
* redcarpet
* sqlite3 (~> 1.3, >= 1.3.13)
* ruby-bbcode-to-md
* reverse_markdown
* tiny_tds
* csv
* parallel
# IMPORT=1 bundle exec rails r /shared/add_in_reverse.rb
* mysql2
* redcarpet
* ruby-bbcode-to-md
* reverse_markdown
* tiny_tds
* csv
* parallel
我根本没有修改 Gemfile;我只想使用 Gemfile 中指定的 sqlite。
为什么有两个 rails/ruby?
问题是路径中的那个是错误的,我应该使用供应商提供的 Ruby 吗?我看到很多 Ruby 和 Rails。但是使用供应商提供的 Ruby 不起作用(或者我不知道如何正确使用它)。
# which ruby
/usr/local/bin/ruby
# which rails
/usr/local/bin/rails
# find /var/www/discourse/ | grep ruby | grep vendor | grep bin | grep rails
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/rails
# /var/www/discourse/vendor/bundle/ruby/3.2.0/bin/rails runner /shared/add_in_reverse.rb
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems.rb:264:in `find_spec_for_exe': can't find gem railties (>= 0.a) with executable rails (Gem::GemNotFoundException)
from /usr/local/lib/ruby/site_ruby/3.2.0/rubygems.rb:283:in `activate_bin_path'
from /var/www/discourse/vendor/bundle/ruby/3.2.0/bin/rails:25:in `<main>'
