How does permalink normalization with regex work?
The discussion revolves around permalink normalization using regex in Discourse. SubStrider explains that a regex is needed to redirect old XenForo URLs (e.g., http://localhost/threads/xyz-abc-is-ghp.223846/) to new Discourse URLs (e.g., http://localhost/t/xyz-abc-is-ghp/274528). The initial regex didn’t work, but pfaffman suggests correcting the syntax, and SubStrider confirms that /threads/[^.]+\.([0-9]+)/?/threads/<1> works. lilstranded confirms it works for single pages but fails for paginated URLs like page-3, asking for a fix.
I went to this setting Admin > Permalinks > Settings
Which says it will apply the regex before matching the permalink.
I have an old xenforo forum URL which is
And the new discourse URL is
When I enter the xenforo URL in the browser without the slug like the following then it is redirecting fine but not with it.
http://localhost/threads/223846/
So I tried to use the following regex to strip the slug out but it seems to be doing nothing. Am I missing a step or is this not how its to be done?
/^(/threads/)[^.]+.(\d+)/?$/+/\1\2
You don’t need a \2. And you need a \ before the period that you’ure searching for. You’ve got only one thing in parentheses. Maybe something like
/^(/threads/)[^.]+\.(\d+)/?$/threads/\1
/threads\/[^.]+\.([0-9]+)\/?/threads/\1
this worked
Hey, im in the same situation and this worked for me! :clinking_beer_mugs:
But when the URL (xenforo URL) has inner pages like for example"https://website[.]com/threads/thread-slug/page-3" then again ill get the " Oops! That page doesn’t exist or is private." error page. Any fix for this?
