您计划使用基于 Ubuntu Xenial 的 Docker 镜像多久?
Hello Discourse team,
I’m considering using Discourse with a Trisquel 8 Docker image, which should work because Trisquel 8 is based on Ubuntu Xenial. The reason I want to do this is so I can use a fully-free distribution instead of one that includes non-free bits here and there. There is no Trisquel 9 release based on Ubuntu Artful yet, so I was wondering how long you plan on sticking with Ubuntu Xenial? If you continue to use it for a year or two, I might be able to use Trisquel as a base image.
Thanks, : )
Andrew
We have no specific plans to move off Xenial at the current time, but we consider the choice of distro inside the container to be an internal implementation detail, not a public interface, so we may well change the container distro at any time.
Incidentally, I think the inclusion of the restricted repo in our container image’s sources.list is unnecessary, and can probably be dropped. If we only use the DFSG-free main and universe repos, doesn’t that produce the same end result as using a different underlying distro?
Hello Matt,
Thanks for your reply. I started a conversation about the repo types here a while back:
Using main and universe alone would be a great improvement. Chances are that you won’t need anything outside of main.
The place I work at cares very much about using fully free distributions, so Ubuntu “man” alone might not be sufficient for our purposes, but I’ll talk to my team about it.
Thanks, :slight_smile:
Andrew
我们已迁移至 Debian,且据我们所知未启用额外的软件源,因此这应能改善您的使用场景。
确实如此!非常感谢您切换到 Debian main!: )
