How much is Discourse affected by a faster CPU?
So I guess these are pretty good then :grinning:
إعجاب واحد (1)
A good starting point is the /about page; you can also refer to the memory stats I quoted in my earlier reply.
I tried on a High CPU Digital Ocean droplet:
sysbench --test=cpu --cpu-max-prime=20000 run
sysbench --test=cpu --cpu-max-prime=40000 --num-threads=8 run
Ali Express mini-pc High CPU droplet
21.3s 24.4s
15.7s 31.6s
(in case it wasn’t obvious, lower numbers are better = faster here)
That’s… quite a bit worse than I expected. You are getting a small slice of a 16 core CPU (and it’s only Broadwell, not even Skylake!) which by definition means very low clock speeds, pushing it down to the i7-7500u levels of ~ 2.6 GHz base and 3.6 Ghz turbo.
https://ark.intel.com/compare/95451,91768
Factoring in Kaby Lake’s generational improvements… it loses by a fair bit. Per the page, they also offer Skylake Xeons at 2.7 Ghz and I think at best that would put it on par (maybe)?
5 إعجابات
That is not entirely true. I have no experience on Azure, but I have heard lots of good thing about it in terms of Perf. It is the best out of the three, Google, AWS and Azure. However it is still much more expensive then other cloud VPS provider like DO and Linode, mostly on bandwidth. Amazon lightsail is extremely slow so don’t even bother with it.
Linode has always offered much better CPU Perf, SSD Speed, and Better Network bandwidth. DO has manage to catch up in Network and SSD, but as far as I can tell Linode still wins on CPU performance, on most of the price plans.
It still doesn’t compare well do a dedicated box though.
في عام 2019، أقوم بترقية خادمي المصغر المخصص إلى:
  • i7-8750h (Coffee Lake، 2.2 - 4.1، 6 نوى / 12 خيط معالجة) - 460 دولارًا على علي إكسبرس
  • 32 جيجابايت من ذاكرة الوصول العشوائي – DDR4 (16 جيجابايت × 2، 220 دولارًا)
  • قرص صلب بسعة 500 جيجابايت – NVMe PCI Samsung 970 Pro (200 دولار)
مقارنة المعالج هنا – قفزة كبيرة في استهلاك الطاقة (TDP)، من نواتين إلى :warning: 6 نوى. زيادة من 16 جيجابايت إلى 32 جيجابايت من ذاكرة الوصول العشوائي DDR4 الأسرع. بالإضافة إلى محرك M.2 NVMe حقيقي، وهو أسرع بكثير من واجهة SATA القديمة.
المواصفات الكاملة
رقم الموديل: Partaker B18
اللون: أسود
المعالج: معالج Intel Core i7-8750H (ذاكرة تخزين مؤقت 9 ميجابايت، تصل إلى 4.10 جيجاهرتز)
المنصة: Coffee Lake، معالجات Intel Core i7 من الجيل الثامن
خيوط المعالجة: 6 نوى و12 خيط معالجة
الرسومات: Intel UHD Graphics 630
ذاكرة الوصول العشوائي: DDR4 2133/2400/2666 260pin، فتحتان SO-DIMM، تدعم حتى 32 جيجابايت
التخزين: M.2 Nvme 22x80 SSD + M.2 NGFF/Nvme 22x80 SSD + 2.5’ 'HD
واي فاي: 2.4G/5G Wifi B/G/N/AC+بلوتوث
نظام التشغيل: Windows أو Linux
بطاقة الشبكة: 10/100/1000 BaseT LAN
منافذ الإدخال/الإخراج: 1xHDMI + 1 Mini DP + 1 منفذ Gigabit LAN + 4 منافذ USB 3.0 + 1 منفذ Type-C USB + 1 منفذ صوتي
مدخل الطاقة: مقبس 5.5 ملم
إخراج HDMI: يدعم HDMI بدقة 4K بمعدل 24 هرتز
إخراج DP: يدعم DP بدقة 4K بمعدل 60 هرتز
إخراج VGA: يدعم VGA بدقة 1080P
الطاقة: الإدخال: DC100-240V AC/50-60Hz، الإخراج: DC 19V/3.42A، 90 واط
درجة حرارة التشغيل: 0°C~80°C (32°F~140°F)
درجة حرارة التخزين: -20°C~80°C (-68°F~176°F)
الرطوبة النسبية: 10%~90% (بدون تكثف)
التصميم الحراري: مروحة منخفضة الضوضاء
الأبعاد: 197 × 197 × 40 ملم
الوزن: 1.5 كجم
محتويات العبوة: جهاز Partaker B18 Mini PC، محول طاقة، كابل طاقة، قوس VESA، مسامير
@pfaffman بمجرد استبدال هذه الأجهزة، سأرسل لك صنادي القديمة، التي لا تزال تعمل بكفاءة.
16 إعجابًا
I hope you left the stubby WiFi antennae on, they are so cute! :heart_eyes:
9 إعجابات
LOL no, I strip those out. These are going in a datacenter where WiFi would only be a negative.
5 إعجابات
I got these boxes and they are nifty designs, a great step up in every way. Burning in overnight now.
This is a really nice, extremely compact layout! One thing that confused me is that the DIMMs are split: one goes on top half, the other goes on the bottom half.
Bottom
Top
You may notice in the second pic in each series, I removed stuff as well as installing memory and SSD. I pulled out the WiFi module and antennas, as well as the SATA bottom mount, since I don’t need it. It looks like there’s another full length NVMe port on the top side as well, which is amazing!
CPU benchmarks
:warning: this newer version of sysbench produces different numbers, it is not comparable to old versions!
sysbench cpu --cpu-max-prime=20000 run
events
DO droplet 2988
2017 scooter 4800
2019 scooter 5671
sysbench cpu --cpu-max-prime=40000 --num-threads=8 run
events
DO droplet 2200
2017 scooter 5588
2019 scooter 14604
Disk benchmarks
ioping -RD -w 10 .
iops MiB/sec
DO droplet 13.7k 53.4
2017 scooter 13.6k 53.2
2019 scooter 14.9k 58.0
dd bs=1M count=512 if=/dev/zero of=test conv=fdatasync
hdparm -Tt /dev/sda
sequential cached reads buffered reads
DO droplet 701 MB/sec 8818 MB/sec 471 MB/sec
2017 scooter 444 MB/sec 12564 MB/sec 505 MB/sec
2019 scooter 1.2 GB/sec 17919 MB/sec 3115 MB/sec
Discourse rebuild times
time ./launcher rebuild app
real user sys
DO droplet 6:59 1.4s 0.89s
2017 scooter 3:41 1.3s 0.85s
2019 scooter 3:24 1.7s 1.2s
Thanks for the tip on the timing command @pfaffman!
18 إعجابًا
This looks like a fun topic!
Are these any good?
ioping -RD -w 10 .
474.9 MiB read, 12.6 k iops, 49.3 MiB/s
537 MB copied, 9.0306 s, 59.5 MB/s
General statistics:
    total time:                          10.0015s
    total number of events:              5289
sysbench cpu --cpu-max-prime=40000 --num-threads=8 run`
General statistics:
    total time:                          10.0044s
    total number of events:              13978
real 3m37.140s
user 0m2.268s
sys 0m0.740s
3 إعجابات
No need to post a bunch of details, anything in the ballpark of the mini-PC numbers shown here is very good. As you can see from my 2019 update, you get to a point where even sizable increases in disk and cpu perf produce diminishing returns.
6 إعجابات
Checking CPU scaling of the new box with i7z and stress. Reminder this is the i7-8750H with 6 cores, 12 threads, 45W TDP.
Here’s one task hogging CPU with stress --cpu 1, we definitely see 4100 Mhz as promised:
Starting with ~10w power consumption with i7z running but nothing else. Let’s exercise us some cores!
typical clock watts
stress --cpu 1 4.1 Ghz 30w
stress --cpu 2 4.1 Ghz 42w
stress --cpu 3 4.0 Ghz 53w
stress --cpu 4 3.9 Ghz 65w*
stress --cpu 5 3.7 Ghz 65w*
stress --cpu 6 3.5 Ghz 65w*
stress --cpu 12 3.3 Ghz 65w*
* It is likely more, you can really see the CPU speed limiters kick in because the watt meter will peak at 75w and then quickly dials it back down to exactly 65w.
Running current-ish versions of mprime jacks this up to 75w though, and overall clock scales down to 3.1 Ghz … those AVX2 extensions are :fire:
Power consumption seems to be about 8w totally idle at the Ubuntu login prompt. Not bad at all!
7 إعجابات
Finally got this deployed so discourse.codinghorror.com is live and running on the above hardware:
10 إعجابات
How are the usual timings on the mini profiler for the latest and a topic page on the new cpu?
إعجاب واحد (1)
Not exactly apples to apples since I did not measure for the old box… but comparing the old numbers from 2017…
topic back button, 113ms avg (prev 206ms)
topic refresh, 179ms avg (prev 127ms)
latest refresh, 131ms avg (prev 140ms)
This is also unfortunately comparing 2017 Discourse with 2019 Discourse… it does look like we regressed a bit on topic refresh perf since then maybe?
10 إعجابات
@pmusaraj recently improved our build yesterday to skip unused locale compression, here’s what I get with
now on the very same machine:
real user sys
2019 scooter 2:40 0.2s 0.1s
Amazing! :raised_hands::raised_hands::raised_hands::raised_hands::raised_hands::raised_hands::raised_hands::raised_hands::raised_hands::raised_hands: that is a 25% improvement!
(I rebuilt twice, because the timing of the first run is affected by the image download time which isn’t technically rebuild time.)
25 إعجابًا
@falco just made a new base image so I initiated a rebuild and tested build time again. Before:
real user sys
After
real user sys
2019 scooter 2:34 0.2s 0.1s
:+1:
13 إعجابًا
I think we have a massive regression in rebuild times currently @falco? I’m seeing 5+ minute rebuilds now where it used to be under 3, on these same machines?
7 إعجابات
Oh since dependabot was enabled we are doing quite a bit of gem upgrades. I’d say a new images should be created in a few days after we finish the bulk of those updates. Just a nokogiri gem update can take so long.
9 إعجابات
Just rebuild an instance using a new base image and it went from 5′6″ to to 3′11″.
New image will be tested on Meta over the weekend and released next week for everyone.
23 إعجابًا
