Hoe voeg je een mooie banner toe zoals op de startpagina van Discourse
The discussion revolves around adding a custom banner to a Discourse forum, similar to the one on the Discourse homepage. Phenix1997 seeks help to customize the banner, including changing text, links, and icons. Don directs them to a related topic on Meta Discourse. Zup provides specific file paths for modifying the banner’s text and links. Ondrej mentions that Discourse uses Font Awesome for icons, and Phenix1997 shares their attempts to replace icons with PNG files, which are not working. Banjo asks about changing Font Awesome icons, and Critical_DevX reports that the banner doesn’t appear on their site.
I want to add some additions that allow placing a banner to welcome visitors,
I check all themes
any plugins or extras
Hi @Phenix1997,
Check this topic :arrow_down:
can you help modify the links!
check
Change the text:
Change the links & icons:
https://github.com/discourse/discourse-meta-banner/blob/main/javascripts/discourse/templates/components/meta-banner.hbs
any icon providers ?
Discourse uses Version 5 Icons | Font Awesome for icons if that is what you mean?
I tried to replace the old icons with a new one and upload them but nothing happen
check
{{#if (and shouldShow discoveryRoute)}}
  <div class="custom-homepage-wrapper">
    <div class="wrap custom-homepage">
      <div class="welcome-wrapper">
        <div class="welcome-content">
          <h2>{{theme-i18n "meta_banner.welcome"}}</h2>
          <p>{{theme-i18n "meta_banner.subtitle"}}</p>
        </div>
        <div class="featured-todo">
          <div>
            <a href="https://forum.ongurutips.com/search?expanded=true">
              <h3>{{d-icon "info-circle"}}
                {{theme-i18n "meta_banner.docs"}}</h3>
            </a>
          </div>
          <div>
            <a href="https://www.fiverr.com/phenix1997">
              <h3>{{d-icon "fab-discourse"}}
                {{theme-i18n "meta_banner.themes"}}</h3>
            </a>
          </div>
          <div>
            <a href="https://ongurutips.com">
              <h3>
                {{theme-i18n "meta_banner.hosting"}}</h3>
            </a>
          </div>
        </div>
      </div>
    </div>
  </div>
{{/if}}
my new icons ! png format
check https://forum.ongurutips.com
How do we change our font awesome icons for the banner
~ a admin on forum.ongurutips.com
Just change these for your preferred icon
I try, no one work. can you suggest other options
Bro how r u using it it won’t show for me
