如何在话题预览中居中显示文本?
Hi, how can I vertically center (bring down) the title, category, and tag on the topic preview next to the image? Thanks.
What about simply:
.main-link {
    display: flex;
    align-items: center;
It should be okay in your case.
Thank you so much :slight_smile:
I’ve noticed that while that works on Desktop, on mobile it remains the uncentered on mobile. (I’ve tried pasting the css into the mobile stylesheet)
Any discovery to this? I’ve been playing around with the code, but no luck
It’s a little more tricky.
I don’t know if it will work in all situations, but you can try and adjust the following:
For mobile only:
.topic-list-item {
    td {
        display: flex;
        max-width: 100%;
        position: relative;
    .topic-details {
        flex: 2;
        display: flex;
        flex-direction: column;
        min-height: initial !important;
        position: initial !important;
        overflow: visible;
        .pull-right {
            position: absolute;
            right: 0;
            top: 0.5em;
            bottom: 0;
        .num.activity {
            bottom: 0.5em;
    .topic-actions {
        flex: 0 0 100%;
What a wonder! Thank you mate!
Another problem arises. The suggested topics table gets completely scattered/broken. Now what can be done :confused: I’ve played around with as much CSS as I know. vertical-align doesn’t work..
Can you show me a screenshot of what you mean?
Then, you should try to target only the main topics list.
What about replacing the selector by: .contents .topic-list-item { ? (note the .contents)
It works a lot better, I noticed that the post count and username of the latest poster gets overlapped when the topic title is 2 lines or longer.
