Hi,
I need to display a banner at the top of the page, but it should be for visitors only. How to set it to disappear for logged users ?
Thanks
Hi,
Thanks
You can make use of the anon class added to the <body> tag. More on this here:
The selector in your case would be inverted like so:
body:not(.anon) {
#banner {
display: none;
Which effectively hides the banner unless the user is logged out.
Este tópico foi automaticamente fechado após 2213 dias. Novas respostas não são mais permitidas.
