(Deprecated) Display a "Discord Widget" in a dropdown button
May 2022
This has has now been converted into a theme component by @keegan :tada::balloon:
Discourse Discord Widget
The Discord Widget does its job, but it’s really cumbersome and generally it’s an eyesore with the style of Discourse.
In the past few months I had tried to implement it everywhere (after-header, body, footer) but every time I found it too big and too customized to be permanently seen.
That’s why, in the end, I decided that a dropdown button would be the best solution. Users can decide if open the widget (maybe only to see the users online) and close it, or click the Connect button to enter the chat.
Desktop View
Display the button for ALL users (logged in and visitors):
Add this script under /admin/customize/themes inside Desktop/Head tab
const { h } = require('virtual-dom');
const { iconNode } = require("discourse-common/lib/icon-library");
api.createWidget('discord-chat-menu', {
  tagName: 'div.discord-panel',
  html() {
    return this.attach('menu-panel', {
      contents: () => h('iframe', {
                        "src": 'https://discordapp.com/widget?id=your-widget-ID&theme=light',
                        "sandbox": "allow-popups allow-popups-to-escape-sandbox allow-same-origin allow-scripts",
                        "width": "350",
                        "height": "500",
                        "allowtransparency": "true",
                        "frameborder": "0",
                        "id": "chatwidget",
                        "name": "chatwidget",}
  clickOutside() {
    this.sendWidgetAction('toggleDiscordChat');
api.decorateWidget('header-icons:before', function(helper) {
  const headerState = helper.widget.parentWidget.state;
  return helper.attach('header-dropdown', {
      title: 'Discord Chat',
      icon: 'fab-discord',
      active: headerState.discordChatVisible,
      action: 'toggleDiscordChat',
api.decorateWidget('header-icons:after', function(helper) {
    if (headerState.discordChatVisible) {
        return [helper.attach('discord-chat-menu')];
api.attachWidgetAction('header', 'toggleDiscordChat', function() {
  this.state.discordChatVisible = !this.state.discordChatVisible;
</script>
Make sure to change the Url here:
  • "src": 'https://discordapp.com/widget?id=your-widget-ID&theme=light', entering your Server ID in place of your-widget-ID. You can find it on Discord in Server Setting > Widget > Server ID.
    E.g. "src": 'https://discordapp.com/widget?id=1234567890123&theme=light',
  • Inside the Url you can also replace the theme style to make it light (&theme=light) or dark (&theme=dark).
  • Change "title": "Discord Chat" as you prefer (e.g. "title": "my wonderful chat")
Add this script under /admin/customize/themes inside Desktop/Body tab to reload and update the iframe every 1.5 mins (made by @Yuun, see here).
Remember to change https://discordapp.com/widget?id=your-widget-ID&theme=light with your Url (e.g. https://discordapp.com/widget?id=1234567890123&theme=light)
<script>
    function reloadIFrame() {
        var disc = document.getElementById("chatwidget");
        if (disc) {
            disc.src="https://discordapp.com/widget?id=your-widget-ID&theme=light";
    window.setInterval("reloadIFrame();", 90000);
</script>
Display the button only to logged in users
const user = require('discourse/models/user').default;
   if (user !== null) {
  html() {
                        "width": "350",
                        "height": "500",
                        "frameborder": "0",
                        "id": "chatwidget",
  clickOutside() {
</script>
Display the button only for users who belong to a certain trust level (and higher or lower - optional)
Change the script in this way:
   var level = User.currentProp("trust_level");
   if (level >=2) {  //Change the trust level here
  html() {
                        "width": "350",
                        "height": "500",
                        "frameborder": "0",
                        "id": "chatwidget",
  clickOutside() {
</script>
In this case, the button is displayed to all users that belong to trust level 2 or higher (>=2). Use only =2 to display it only for users at trust level 2 (no higher), or (<=2) for users that belong to trust level 2 or lower. You can change the trust level (from 0 to 4) as needed. For more information about trust levels read Understanding Discourse Trust Levels
Display the button only for users who belong to staff (admins + mods) [@Neuferkar]
   const user = User.currentProp();
    if (user !== null && user.staff) {
  html() {
                        "width": "350",
                        "height": "500",
                        "frameborder": "0",
                        "id": "chatwidget",
  clickOutside() {
</script>
Change this line if (user !== null && user.staff) as you wish to display the button only to admins or only to mods:
  • if (user !== null && user.administrator)
  • if (user !== null && user.moderator)
Display the button only to members of a primary group (e.g. “footeam”) [@Neuferkar and @cpradio]
Be sure to target the primary_group_name correctly (see here)
if (user !== null && user.primary_group_name === "footeam") {
  html() {
                        "width": "350",
                        "height": "500",
                        "frameborder": "0",
                        "id": "chatwidget",
  clickOutside() {
</script>
Mobile View
For mobile I use an icon with an invite Url to my server since on phones there is a cool Discord App to install.
Just add to your site the Custom Header Links (icons) theme component and enter in the theme settings:
  • Header links: Mobile-only link,fab-discord,https://discord.gg/INVITE_ID,vmo,blank
  • Svg icons: fab-discord
Remember to generate an invite of infinite duration, so it will always be valid and you will not have to change it again and make sure to update the Url from https://discord.gg/INVITE_ID to your real invite ID:
49 лайков
В
      icon: 'discord',
icon: 'discord' следует заменить на icon: 'fab-discord'.
2 лайка
Готово.
Этот гид — вики-страница, не стесняйтесь редактировать и улучшать его!
5 лайков
Обновил исходный пост для исправления неработающего виджета
1 лайк
Есть ли планы сделать это официальным плагином? Так будет проще его поддерживать. Спасибо за то, что поделились этим!
5 лайков
Думаю, это может быть TC.
2 лайка
Привет! Спасибо за разработку этого виджета! Я только что добавил его на наш форум, следуя вашей инструкции, и хотя виджет отображается корректно, он, похоже, не подключается (бесконечно пытается загрузиться… см. скриншот ниже). Я трижды проверил, что скопированный код на 100% точен, но он всё равно не загружается правильно. Также я правильно указал ID сервера Discord во всех соответствующих разделах.
Любая помощь будет очень кстати!
1 лайк
Копирование и вставка всего этого кода, пожалуй, немного небрежно и чревато ошибками. У кого-то, у кого есть время и личный интерес, должно появиться желание опубликовать это в виде компонента темы и применять соответствующие исправления (и создать для него тему в разделе Customization > Theme).
1 лайк
Убедитесь, что вы включили «Виджет сервера» в Discord в разделе «Настройки сервера» > «Виджет»
1 лайк
Привет, ребята! Я взял этот потрясающий гайд и упаковал его в легко устанавливаемый компонент темы:
4 лайка
Спасибо за это руководство. В итоге я немного его доработал и встроил WidgetBot. Я надеялся использовать crate WidgetBot вместо iframe, но возникли проблемы с загрузкой внешнего JavaScript, поэтому пока это решение меня устраивает.
Также я заметил несколько проблем. Метод проверки только для авторизованных пользователей не работал, и иконка отображалась даже при отсутствии авторизации. Поэтому я использовал метод проверки уровня доверия с условием >= 1. Ещё одна проблема: ширина, кажется, не увеличивается больше 350 (я не думаю, что это проблема кэша, так как пробовал в режиме инкогнито и в разных браузерах). Высота же, кажется, подстраивается корректно.
const { h } = require("virtual-dom");
var level = Discourse.User.currentProp("trust_level");
// проверяем, что пользователь авторизован и имеет уровень доверия 1 или выше
if (level >= 1) {
    api.createWidget("discord-chat-menu", {
        tagName: "div.discord-panel",
        html() {
            return this.attach("menu-panel", {
                contents: () =>
                    h("iframe", {
                        src: "https://e.widgetbot.io/channels/<server_id>/<channel_id>",
                        sandbox: "allow-popups allow-popups-to-escape-sandbox allow-same-origin allow-scripts",
                        width: "400",
                        height: "500",
                        allowtransparency: "false",
                        frameborder: "0",
        clickOutside() {
            this.sendWidgetAction("toggleDiscordChat");
    api.decorateWidget("header-icons:before", function (helper) {
        return helper.attach("header-dropdown", {
            title: "Discord Chat",
            icon: "fab-discord",
            action: "toggleDiscordChat",
    api.decorateWidget("header-icons:after", function (helper) {
            return [helper.attach("discord-chat-menu")];
    api.attachWidgetAction("header", "toggleDiscordChat", function () {
</script>
Это устарело, теперь следует использовать
User.currentProp
Тогда вы можете использовать >= 0, так как пользователи с уровнем доверия 0 также являются зарегистрированными.
Если я правильно помню, значение 350 было прописано в коде iframe для Discord? :thinking:
Отличная идея. Я всё ещё новичок в Discourse и нахожусь в режиме «запуска», где все находятся на уровне 1. Я это исправлю.
Да, но я это изменил…
                    "iframe", {
                        width: "400",
                        height: "500",
                        frameborder: "0",
WidgetBot точно не имеет ограничений на размер iframe… изображение с моего сайта.
