¿Cómo editar robot.txt para indexar perfiles de usuario?
I want the user profiles on my website to get indexed in Google. I know it might attract a lot of spam but we can handle that, although getting user profiles indexed in Google is more important for us. So is there a way to do this?
I checked the old topics on meta and they suggested to edit robot.txt. Is the answer still the same? And if the yes, then how to edit the robot.txt?
User profiles are disallowed as the version which is seen by the crawler contains no useful information.
It’s not a question of whether the server can handle it or “take the hit”, it’s the tens of thousands of effectively empty pages which will waste the crawl time allocated to your site by the search engines.
You are absolutely right, for most websites your answer makes absolute sense. But, my use case is slightly different and that’s why I wanted to know how to index user profiles. Even if tons of useless pages (user profiles) gets indexed, then also that’s what I need for my use case.
If there’s a way to achieve it then, please let me know. :slight_smile:
I am also want to index the Categories and Tags.
Is there a way to edit the robots.txt?
Search meta, the reasons this is disabled is well documented.
@Stephen, ahora que podemos “jugar” con robots.txt aquí → /admin/customize/robots, ¿recomiendan que permitamos esos dos → Disallow: /tags - Disallow: /tags/?
No recomendamos en absoluto que te metas con esto.
Viejo, pero hay un truco rápido: envía un Gmail con un enlace a la categoría de usuario, etiquetas, etc. y deja que los usuarios —como administradores y moderadores— abran esos enlaces. Entonces Googlebot no seguirá robots.txt y los indexará.
El resto es, como siempre, cuestión de que Google decida si sigue más a fondo o se olvida.
Este tema, y muchos similares, dan la impresión aquí de que robots.txt sería una regla estricta. No lo es. Es solo una guía, nada más.
Y el miedo al spam/robo es válido, pero los bots basura no se preocupan por lo que hay en robots.txt. Si algo es accesible, irán allí.
