Hi, I try to find a picture posted by myself .
Searched patterns are: png
, jpg
, gif
or picture
- no success. The search function returns only images generated by graphviz.
Is any way to find an image by extension?
, jpg
, gif
or picture
To find all images you posted, search for
@username with:images
This is also available in the advanced search UI. Add search terms or order to taste.
Thank you so much for the response!
But I am not sure that I understand how it works, tested on try. It returns posts with word image
. After replacing this word to picture
the search is empty:
It has to say with:images
, I suggest visiting the advanced search UI so we do not make typos here.
Sorry, never mind . I found this options, thatβs amazing. Solved!
