Come contrassegnare un argomento come risolto?
How do you mark a reply as being the “best answer” and mark the topic as being “resolved”?
I don’t think that’s a native feature (feel to correct me if I’m wrong, folks) and would require a plugin, but one thing I do on my non-Discourse forum is simply edit the title of the thread to include [Resolved] at the beginning. The best answer would be the one that gets most likes, or you could use staff coloring to make it stand out.
I noticed the staff coloring option. Can you change the staff color?
Yep. Sure can! Found this old closed post.
https://meta.discourse.org/t/changing-the-color-of-staff-color-admin-customize-colors/27973
Oh, just realized this button is available below:
Does anyone know what plugin is used for this?
You need to install the #plugin:solved plugin
Just what I needed. Thank you!
