I am trying to add another new tab in the plugin outlet user-activity-bottom ( after Solved,Votes …) .
After adding a vertical tab, how do I display its data on the right side.
The template file that has this plugin-outlet is activity.hbs , its contoller is user-activity.js.es6.
The activity.hbs has following code for “section right”
<section class='user-right'>
{{outlet}}
</section>
I was not able to understand how are the questions on the right side being populated, where are its templates located
Hi,
If you look at app-route-map.js.es6, you will see that the routes for the activity types (topics, replies, bookmars, etc.) are nested inside the user.userActivity route, so you could create a route map:
export default{
resource: 'user.userActivity',
path: '/u/:username/activity',
map(){
this.route('newStream', { path: 'new-stream' });
then create a template user-activity-new-stream.hbs (this will be displayed inside the outlet you mentioned before) and link to that route in your user-activity-bottom connector.
Also, in case you wonder, the activity types routes use the user-stream and the stream-item components to populate the right side section.
Thankyou @jafeth.diazc, I was able to add the route.
