Hoe verplaats ik een Lightsail S3-bucket naar een officiële AWS S3-bucket en CloudFront CDN?
quangmai911 is seeking advice on migrating from AWS Lightsail S3 buckets to official AWS S3 buckets with CloudFront CDN, after resolving initial S3 policy issues. They’ve successfully configured a new S3 bucket but haven’t yet switched the CDN, and want to know the smoothest way to migrate uploads and rebake posts without data loss. pfaffman suggests enabling include_s3_uploads_in_backups, setting the site to read-only, backing up, restoring to the new setup, and switching DNS — keeping the old system temporarily for safety. They note that multi-bucket setups complicate migration. Mr.X_Mr.X asks quangmai911 to share the S3 policy solution since the referenced @RedBear posts are deleted. The discussion centers on safe, structured migration from Lightsail to AWS S3 with CDN continuity.
Hello all,
I need some help or idea to achieve this.
Continuing the discussion from Setting up file and image uploads to S3:
Long story short:
  • Initially, I tried to setup my AWS S3 bucket for upload and backup then I got the issue with bucket policy ACLs did not allow to upload my files to S3 bucket.
  • Temporary solution, I setup 2 AWS Lightsail buckets one for upload and one for backup. These two buckets work perfectly with the Cloudfront CDN setup. All working well however I still want to get the main stream done correctly!
  • Final solution, with the post from @RedBear, I finally manage to get the AWS S3 bucket running with the proper S3 Policy set up. Note: I haven’t switched the old Cloudfront to the new Cloudfront CDN yet.
My question before I attempt to do the rake tasks:
rake uploads:migrate_to_s3
rake posts:rebake
  • What is the best and smooth solution to achieve the migration from old S3 bucket with old CloudfrontCDN to the new S3 bucket with the new CloudFront CDN?
Note: At the moment my new S3 uploads bucket is empty.
Thanks so much.
Quang
There is Moving from one S3 bucket to another, which is not very easy.
I think what I would do, if everything is still on the lightsail buckets as you say, is to
  • turn on the hidden SiteSetting.include_s3_uploads_in_backups=true on the site with old buckets
  • set read only
  • make a backup
  • restore that backup to the newly configured system
  • switch DNS to new system
I would keep the old system in place for a bit until you’re sure everything is straight on the new one.
If you have things in multiple buckets on a single instance things get much more complicated. I’ve got a couple of sites that way that I’ve been trying off-and-on to get straight for longer that I care to admit publicly.
Can you post the solution? The @RedBear posts are deleted.
