Comment intégrer un lecteur Simplecast audio via oembed
I fixed this bug. :blush: To give a little bit more of a context of what happened here:
Last time I worked on this I added some logic that was a little bit more complicated than needed because Simplecast has a bug, and unfortunately this workaround introduced a bug. :slightly_frowning_face:
Usually, https://simplecast.com/oembed?url=URL should return a JSON with some information, but for specific links it does not work.
For example,
https://tgd.simplecast.com/episodes/dan-blackman-and-robyn-kanner-the-power-7fe152f4
https://simplecast.com/oembed?url=https://tgd.simplecast.com/episodes/dan-blackman-and-robyn-kanner-the-power-7fe152f4
Response:
Not Found
Let’s see if it works:
https://the-podcast-fellowship.simplecast.com/episodes/58eb0d24
Awesome, thank you @nbianca :trophy:
