Como ler texto inserido dentro de tags HTML
How do you read invis text
Invisible text? Not possible my eyes can’t either :rofl:
I am guessing you mean spoiler text like this? If so you just press on it.
or <text here> is not visible in when you post
Uhh on my forum u just spam random numbers between 2 symbols like this: <skskksksksks. Jdjdjdjd> and it creates invis text. It didn’t create it in the example because I put some other symbols (like the dot). I come from the Hive forums.
Are you a staff member?
Add this to your site if not ask an admin to do it. It is configurable with TL’s
Then press show raw post:
1 curtida
