Hello! I am a beginer, so I hope for your help. I want to change the content in …. When I open the source files, I see that the “header-content” widget says:
If you check the browser console, you’ll see something like this
ReferenceError: hbs is not defined
but even if you fix that, you would still have problems getting this to work because templates are supposed to be precompiled on the server, not the client-side.
We many ways to customize the header. If you let me know what you’re trying to do, I can probably share a way for you to achieve the result you want.
Greetings, Joe! Thank you very much for your responsiveness. I want to say that I’m starting to like Discourse very much, but there are some difficulties that I haven’t managed to cope with yet. In general, I have one big wish: I want to be able to embed my html code wherever I want, in any tag, and I want to be able to remove some elements that I consider superfluous.
Can you add a screenshot of where you want to add new elements?
If your site doesn’t need that element, you can hide it with CSS. So, something like this.
#navigation-bar {
display: none;
That said, that element gives users an easy way to navigate between the different filters for topic lists, and I don’t recommend removing it - especially on mobile.
However, you know your community more than anyone. So, if it works for you, then… great
That’s what I mean. I need to place my custom block where I pointed with the arrow in the screenshot.
I’m uploading another screenshot so you can better understand what result I want to get:
Thank you again for your responsiveness. I have quite good css skills. I know that by writing display: none I can hide the element. But I would like to have a stronger experience. I would like to be able to manage templates and widgets like a true professional. I guess there is a way to do it more correctly. For example, rewrite the template or something else.
