Come targeting specifici elementi CSS?
I want to target a specific element to modify its properties (for example):
.d-button-label { display: none !important;}
But then realized it’s used all over the place in Discourse, not just in the plugin element I was trying to customize. So how would I go about targeting that specific label?
Screen Shot 2020-04-06 at 10.35.15 PM copy
3 Mi Piace
You go up in the HTML tree and find a parent with a unique class.
You can then add the parent to your selector like so
.parent-class .child-class {
  display: none;
You can also add more unique parent classes like so
.grandparent-class .parent-class .child-class {
  display: none;
If needed.
The same thing in SCSS would look like this
.grandparent-class {
  .parent-class {
    .child-class {
      display: none;
This should eliminate the need to use !important
7 Mi Piace
Thank you @Johani! You just taught me something new that will come in very handy!
3 Mi Piace
