איך לצפות ב-.docs או .docx כהצצה או בכרטיסיה אחרת בדיסקורס
Dear All,
I need your support to have the possibility to view word documents as pdf preview or another tab
or if there’s a specific plugin
https://stackoverflow.com/questions/27957766/how-do-i-render-a-word-document-doc-docx-in-the-browser-using-javascript discusses a few ways this might be possible. It should be possible to create a theme component that could do previews.
You could ask in Marketplace if you have a budget.
Not directly word documents. But the 2nd part “as pdf”. There is a #theme-component or #plugin for inline pdf viewing.
Plugin
A doc preview component would be awesome.
