HTML in site settings field for a plugin
I’m trying to figure out how to have some custom HTML added to a plugin setting and then display that HTML safely in a widget.
My widget code is the following:
import { createWidget } from 'discourse/widgets/widget';
import { h } from 'virtual-dom';
createWidget('sidebar-custom-content', {
  tagName: 'div.sidebar-custom-content',
  html(attrs) {
    return h('div', Discourse.SiteSettings.sidebar_custom_content);
and the plugin settings.yml has this:
  sidebar_custom_content:
    type: text
    default: ''
    client: true
As it is, if I enter HTML in the setting field, it gets output as regular text.
Found the solution to my own question. Replace this line:
with
return h('div', {innerHTML: Discourse.SiteSettings.sidebar_custom_content});
I’m surprised this works! From what I saw in the virtual dom library that might break things. The way we do it is like this:
html(attrs) {
  return new RawHtml({ html: `<div>${this.siteSettings.sidebar_custom_content}</div>` });
Of course you have to import RawHtml from 'discourse/widgets/raw-html'; too.
