يتم طلب رد اتصال HTTP OAuth حتى إذا تم تفعيل HTTPS
I have HTTPS enabled on my site, enforced by a 301 redirect from HTTP to HTTPS by the reverse proxy in front of it. When I tried to login with Google, Google complained that the requested callback URL did not match the registered callback URL, the difference being that the registered callback URL uses HTTPS, and the requested URL uses HTTP..
That would be the cause, you need to ensure NGINX has the headers set correctly, when we need to enforce this we add:
 - replace:
         filename: /etc/nginx/conf.d/discourse.conf
         to: https;
         global: true
Where does that go? I tried adding it web_only.yml, under
hooks:
  after_code:
And got
Errno::ENOENT: No such file or directory - /etc/nginx/conf.d/discourse.conf
after_web_config:
