I’m having some issues with put request to my discourse from the api.
I can make, post and get request, but when I try to make a put request it doesn’t work.
My put request works, when I have the GOOGLE CORS extension on.
I am making api call from Angular localhost:4200.
I enable CORS inside the discourse management, which work fine with my other request, just not for my put request.
This is my error:
This is the header which I use
And this is my method, which does not work when I don’t use the google chrome extension
addAboutCompetition(postId, dataForm) {
const competitionForm = dataForm.value;
const prize = competitionForm.competitionPrize;
const description = competitionForm.competitionDescription;
const endDate = competitionForm.competitionEndDate;
console.log(endDate);
const aboutText = '|type|normal|type| |endeDate|' + endDate + '|endeDate| |winner|false-/-null-/-none-/-avatar-/' +
'-name-/-username|winner||price|' + prize + '-/p/-|price|' +
'|text|<br><strong>UDFORDRINGEN</strong><br>' + description + '|text|';
const data = new FormData();
data.append('api_key', WLIApiKey);
data.append('api_username', WLIUsername);
data.append('post[raw]', aboutText);
return this.http.put(url + '/posts/' + postId, data, {
headers
I think it has something to do with my header maybe ?
