I tried to install metadiscource as the link says :
Set up Discourse in the cloud in under 30 minutes
result:
ideas?
result:
ideas?
Perhaps don’t make your CDN address discourse-cdn.example.com, since I’m guessing you don’t own that domain?
without CDN
app.yml
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "3000:3000" # http
- "443:443" # https
DISCOURSE_DEVELOPER_EMAILS: 'zerodump2@gmail.com'
DISCOURSE_HOSTNAME: 'huelen.diinf.usach.cl'
## TODO: The SMTP mail server used to validate new accounts and send notifications
DISCOURSE_SMTP_ADDRESS: smtp.gmail.com # required
DISCOURSE_SMTP_PORT: 465 # (optional, default 587)
DISCOURSE_SMTP_USER_NAME: xxxxxxx # required
DISCOURSE_SMTP_PASSWORD: xxxxxx # required, WARNING the char '#' in pw can cause problems!
DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## The CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
## DISCOURSE_CDN_URL: //discourse-cdn.example.huelen.diinf.usach.cl
Port 3000 is not supported, in fact, no custom ports are supported for a production (non development) install. You have a broken install.
you say you have to install it again, or would suffice to change the port on app.yml , and apply a rebuild.
You should probably wipe the database:
rm -rf /var/discourse/shared/standalone/postgres*
thanks, change port 80, and has he corrected.
