I installed discourse on the server with Webmin. I can see the discourse when i do this ipadress:3001 but i can’t see it on forum.myadress.com
How can I solve this problem?
Webmin panel, i don’t use nginx. I’m using apache2.
Thanks.
Murto installed Discourse via Webmin and can access it at ipaddress:3001, but not via a subdomain like forum.myaddress.com. The community clarifies that Discourse is not supported on non-standard ports like 3001 — it must run on port 80 or 443 for proper functionality and support. Stephen and Ghan explain that while Apache2 can act as a reverse proxy, Discourse’s official setup includes its own nginx container and doesn’t require an external web server. Murto confirms the installation appears correct but admits they couldn’t bind to ports 80/443. Stephen reiterates that without a supported configuration — specifically using standard ports — further assistance cannot be provided. Users are directed to search for topics on Apache reverse proxy setups using the socketed template if they insist on using Apache. The root issue is the non-standard port usage, which breaks expected behavior for subdomains and SSL, and is outside Discourse’s supported installation scope.
Thanks.
I’m sorry, but Discourse isn’t supported on non-standard ports.
You’re going to need to install on :80/:443 to get any assistance here.
If you use the search you will find several topics on using Apache as a reverse proxy, but as Discourse includes nginx within the container no external web server is required for installation.
What does it mean? The installation was successful. ![]()
I’m not sure what this means. I’ve not used Webmin, so how was Discourse installed? Does it install using the official installer Docker container as shown in the install guide?
The container should bind to 80/443 by default but it sounds like it did not or is in a development setup.
I could’nt install the discourse on these ports. I was only able to setup it like this.
I don’t quite understand what that is, though. Did you run the ./discourse-setup script and fill in the prompts? Did the container build correctly? Do the entries in /var/discourse/containers/app.yml appear correct?
Yes everything is correct and working.
As you’ve already found from your install, Discourse won’t work correctly on a non standard-port. We can’t help you here unless you install it in a supported configuration.
If you’re going to use Apache2 as a reverse proxy you’re going to need to look at one of the topics here which discusses using the socketed template.
