In usual photo upload, the photo gets automatically gets added like this.
I have enabled the following setting in admin panel (and want to keep it)
Enable automatic deletion policy for tombstone uploads. IMPORTANT: If disabled, no space will be reclaimed after uploads are deleted.
If I go directly to that image from browser, it will display in a different url format like the following. I hope this is the direct link for that upload (and the CDN link as I see).
https://d2963qmas5o2k254.cloudfront.net/original/1X/ec25e63d2a1s4e5re2s6b77824d99696c7eae85632.png
My question is,
If I use the direct link (`https ://d29… etc) instead of the (upload://be90 … etc), will the discourse consider it as a orphaned imaged and remove the uploaded image? Or will it be fine to use both the links?
or else is there any alternative way to use the image within a post than using
