(No longer supported) Import posts from Facebook group into Discourse
@Mittineague
I’m testing this importer on a dummy Discourse with 1 admin user.
I think there was some errors at fetching facebook names (This importer uses Facebook FQL to interactive with Graph API which is deprecated)
def fb_username_to_dc(name)
  # Create username from full name, only letters and numbers
  username = name.tr('^A-Za-z0-9', '').downcase
  # Maximum length of a Discourse username is 15 characters
  username = username[0,15]
I added puts name, nothing was written.
Well… this is a very old import script. :slight_smile: I’ll see if I can find the time to have a look at it. I never did, cause my groups were converted back then.
Thanks you very much :smile: @Sander78
Follow up:
I’m debuging your script. Here some error that I found:
Facebook doesn’t return username anymore, so I use name instead.
Line 257 => fb_writer[‘name’]
Line 273 => fb_writer[‘name’]
Here is the full code:
#### IMPORT FACEBOOK GROUP INTO DISCOURSE
#### created by Sander Datema (info@sanderdatema.nl)
#### version 1.6.1 (11/07/2013)
#### Description
# This rake task will import all posts and comments of a
# Facebook group into Discourse.
# - It will preserve post and comment dates
# - It will not import likes
# - It will create new user accounts for each imported user
#   using username@localhost as email address and the full
#   name of each user converted to lower case, no spaces as
#   username
# - It will use the first 50 characters of the post as title
#   for the topic
#### Prerequisits
# - A Facebook Graph API token. get it here:
#   https://developers.facebook.com/tools/explorer
#   Select user_groups and read_stream as permission
# - Add this to your Gemfile:
#   gem 'koala', require: false
# - Edit the configuration file config/import_facebook.yml
#### The Rake Task
require 'koala'
desc "Import posts and comments from a Facebook group"
task "import:facebook_group" => :environment do
  # Import configuration file
  @config = YAML.load_file('config/import_facebook.yml')
  TEST_MODE = @config['test_mode']
  FB_TOKEN = @config['facebook_token']
  FB_GROUP_NAME = @config['facebook_group_name']
  DC_CATEGORY_NAME = @config['discourse_category_name']
  DC_ADMIN = @config['discourse_admin']
  REAL_EMAIL = @config['real_email_addresses']
  if TEST_MODE then puts "\n*** Running in TEST mode. No changes to Discourse database are made\n".yellow end
  unless REAL_EMAIL then puts "\n*** Using fake email addresses\n".yellow end
  # Some checks
  # Exit rake task if admin user doesn't exist
  unless dc_user_exists(DC_ADMIN) then
    puts "\nERROR: The admin user #{DC_ADMIN} does not exist".red
    exit_script
  # Setup Facebook connection
  fb_initialize_connection(FB_TOKEN)
  # Collect IDs
  group_id = fb_get_group_id(FB_GROUP_NAME)
  # Fetch all facebook posts
  fb_fetch_posts(group_id, current_unix_time)
  if TEST_MODE then
    exit_script # We're done
  else
    # Create users in Discourse
    dc_create_users_from_fb_writers
    # Backup Site Settings
    dc_backup_site_settings
    # Then set the temporary Site Settings we need
    dc_set_temporary_site_settings
    # Create and/or set Discourse category
    dc_category = dc_get_or_create_category(DC_CATEGORY_NAME, DC_ADMIN)
    # Import Facebooks posts into Discourse
    fb_import_posts_into_dc(dc_category)
    # Restore Site Settings
    dc_restore_site_settings
  puts "\n*** DONE".green
  # DONE!
#### Methods
# Returns the Facebook Group ID of the given group name
# User must be a member of given group
def fb_get_group_id(groupname)
  groups = @graph.get_connections("me", "groups")
  groups = groups.select {|g| g['name'] == groupname}
  groups[0]['id']
# Connect to the Facebook Graph API
def fb_initialize_connection(token)
  begin
    @graph = Koala::Facebook::API.new(token)
    test = @graph.get_object('me')
  rescue Koala::Facebook::APIError => e
    puts "\nERROR: Connection with Facebook failed\n#{e.message}".red
    exit_script
  puts "\nFacebook token accepted".green
def fb_fetch_posts(group_id, until_time)
  @fb_posts ||= [] # Initialize if needed
  time_of_last_imported_post = until_time
  # Fetch Facebook posts in batches and download writer/user info
  loop do
    query = "SELECT created_time,
                    updated_time,
                    post_id,
                    actor_id,
                    permalink,
                    message,
                    comments
             FROM stream
             WHERE source_id = '#{group_id}'
               AND created_time < #{time_of_last_imported_post}
             LIMIT 500"
    result = @graph.fql_query(query)
    break if result.count == 0 # No more posts to import
    # Add the results of this batch to the rest of the imported posts
    @fb_posts = @fb_posts.concat(result)
    puts "Batch: #{result.count.to_s} posts (since #{unix_to_human_time(result[-1]['created_time'])} until #{unix_to_human_time(result[0]['created_time'])})"
    time_of_last_imported_post = result[-1]['created_time']
    result.each do |post|
      fb_extract_writer(post) # Extract the writer from the post
      comments = post['comments']['comment_list']
      if comments.count > 0 then
        comments.each do |comment|
          fb_extract_writer(comment)
  puts "\nAmount of posts: #{@fb_posts.count.to_s}"
  puts "Amount of writers: #{@fb_writers.count.to_s}"
# Import Facebook posts into Discourse
def fb_import_posts_into_dc(dc_category)
  post_count = 0
  @fb_posts.each do |fb_post|
    post_count += 1
    # Get details of the writer of this post
    fb_post_user = @fb_writers.find {|k| k['id'] == fb_post['actor_id'].to_s}
	p fb_post_user
    # Get the Discourse user of this writer
    dc_user = dc_get_user(fb_username_to_dc(fb_post_user['name']))
    # Facebook posts don't have a title, so use first 50 characters of the post as title
    topic_title = fb_post['message'][0,50]
    # Remove new lines and replace with a space
    topic_title = topic_title.gsub( /\n/m, " " )
    progress = post_count.percent_of(@fb_posts.count).round.to_s
    puts "[#{progress}%]".blue + " Creating topic '" + topic_title.blue + "' (#{Time.at(fb_post['created_time'])})"
    post_creator = PostCreator.new(dc_user,
                                   raw: fb_post['message'],
                                   title: topic_title,
                                   archetype: 'regular',
                                   category: DC_CATEGORY_NAME,
                                   created_at: Time.at(fb_post['created_time']))
    p Time.at(fb_post['created_time'])
    p fb_post['created_time']
    Time.now - 1.week
    Time.at(Time.now - 1.week)
    post = post_creator.create
    # Everything set, save the topic
    unless post_creator.errors.present? then
      topic_id = post.topic.id
      post_serializer = PostSerializer.new(post, scope: true, root: false)
      post_serializer.topic_slug = post.topic.slug if post.topic.present?
      post_serializer.draft_sequence = DraftSequence.current(dc_user, post.topic.draft_key)
      puts " - First post of topic created".green
      # Now create the replies, using the Facebook comments
      unless fb_post['comments']['count'] == 0 then
        fb_post['comments']['comment_list'].each do |comment|
          # Get details of the writer of this comment
          comment_user = @fb_writers.find {|k| k['id'] == comment['fromid'].to_s}
          dc_user = dc_get_user(fb_username_to_dc(comment_user['username']))
                                         raw: comment['text'],
                                         topic_id: topic_id,
                                         created_at: Time.at(comment['time']))
          else # Skip if not valid for some reason
            puts " - Comment (#{comment['id']}) failed to import, #{post_creator.errors.messages[:raw][0]}".yellow
          puts " - #{fb_post['comments']['count'].to_s} Comments imported".green
      puts "Contents of topic from Facebook post #{fb_post['post_id']} failed to import, #{post_creator.errors.messages[:base]}".yellow
# Returns the Discourse category where imported Facebook posts will go
def dc_get_or_create_category(name, owner)
  if Category.where('name = ?', name).empty? then
    puts "Creating category '#{name}'"
    owner = User.where('username = ?', owner).first
    category = Category.create!(name: name, user_id: owner.id)
  else
    puts "Category '#{name}' exists"
    category = Category.where('name = ?', name).first
# Create a Discourse user with Facebook info unless it already exists
def dc_create_users_from_fb_writers
  @fb_writers.each do |fb_writer|
    # Setup Discourse username
    dc_username = fb_username_to_dc(fb_writer['name'])
    # Create email address for user
    if fb_writer['email'].nil? then
      dc_email = dc_username + "@localhost.fake"
    else
      if REAL_EMAIL then
        dc_email = fb_writer['email']
      else
        dc_email = fb_writer['email'] + '.fake'
    # Create user if it doesn't exist
    if User.where('username = ?', dc_username).empty? then
      dc_user = User.create!(username: dc_username,
                             email: dc_email,
                             approved: true,
                             approved_by_id: dc_get_user_id(DC_ADMIN))
      # Create Facebook credentials so the user could login later and claim his account
      FacebookUserInfo.create!(user_id: dc_user.id,
                               facebook_user_id: fb_writer['id'].to_i,
                               username: fb_writer['name'],
                               first_name: fb_writer['first_name'],
                               last_name: fb_writer['last_name'],
                               name: fb_writer['name'].tr(' ', '_'),
                               link: fb_writer['link'])
      puts "User #{fb_writer['name']} (#{dc_username} / #{dc_email}) created".green
# Backup site settings
def dc_backup_site_settings
  @site_settings = {}
  @site_settings['unique_posts_mins'] = SiteSetting.unique_posts_mins
  @site_settings['rate_limit_create_topic'] = SiteSetting.rate_limit_create_topic
  @site_settings['rate_limit_create_post'] = SiteSetting.rate_limit_create_post
  @site_settings['max_topics_per_day'] = SiteSetting.max_topics_per_day
  @site_settings['title_min_entropy'] = SiteSetting.title_min_entropy
  @site_settings['body_min_entropy'] = SiteSetting.body_min_entropy
# Restore site settings
def dc_restore_site_settings
  SiteSetting.send("unique_posts_mins=", @site_settings['unique_posts_mins'])
  SiteSetting.send("rate_limit_create_topic=", @site_settings['rate_limit_create_topic'])
  SiteSetting.send("rate_limit_create_post=", @site_settings['rate_limit_create_post'])
  SiteSetting.send("max_topics_per_day=", @site_settings['max_topics_per_day'])
  SiteSetting.send("title_min_entropy=", @site_settings['title_min_entropy'])
  SiteSetting.send("body_min_entropy=", @site_settings['body_min_entropy'])
# Set temporary site settings needed for this rake task
def dc_set_temporary_site_settings
  SiteSetting.send("unique_posts_mins=", 0)
  SiteSetting.send("rate_limit_create_topic=", 0)
  SiteSetting.send("rate_limit_create_post=", 0)
  SiteSetting.send("max_topics_per_day=", 10000)
  SiteSetting.send("title_min_entropy=", 1)
  SiteSetting.send("body_min_entropy=", 1)
# Check if user exists
# For some really weird reason this method returns the opposite value
# So if it did find the user, the result is false
def dc_user_exists(name)
  User.where('username = ?', name).exists?
def dc_get_user_id(name)
  User.where('username = ?', name).first.id
def dc_get_user(name)
# Returns current unix time
def current_unix_time
  Time.now.to_i
def unix_to_human_time(unix_time)
  Time.at(unix_time).strftime("%d/%m/%Y %H:%M")
# Exit the script
def exit_script
  puts "\nScript will now exit\n".yellow
  exit
def fb_extract_writer(post)
  @fb_writers ||= [] # Initialize if needed
  if post.has_key? 'actor_id' # Facebook post
    writer = post['actor_id']
  else # Facebook comment
    writer = post['fromid']
  # Fetch user info from Facebook and add to writers array
  unless @fb_writers.any? {|w| w['id'] == writer.to_s}
    @fb_writers << @graph.get_object(writer)
# Add colors to class String
class String
  def red
    colorize(self, 33);
  def green
    colorize(self, 32);
  def yellow
    colorize(self, 33);
  def blue
    colorize(self, 33);
  def colorize(text, color_code)
    "\033[#{color_code}m#{text}\033[0m"
# Calculate percentage
class Numeric
  def percent_of(n)
    self.to_f / n.to_f * 100.0
But I can’t get this script work. It show an error with post creator
rake aborted!
NoMethodError: undefined method `topic_slug=' for #<PostSerializer:0xd4891a0>
/vagrant/lib/tasks/import_facebook.rake:204:in `block in fb_import_posts_into_d
/vagrant/lib/tasks/import_facebook.rake:170:in `each'
/vagrant/lib/tasks/import_facebook.rake:170:in `fb_import_posts_into_dc'
/vagrant/lib/tasks/import_facebook.rake:88:in `block in <top (required)>'
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rake-10.4.0/lib/rake/task.rb:240:i
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rake-10.4.0/lib/rake/task.rb:235:i
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rake-10.4.0/lib/rake/task.rb:179:i
/usr/local/rvm/rubies/ruby-2.0.0-p0-turbo/lib/ruby/2.0.0/monitor.rb:211:in `mon
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rake-10.4.0/lib/rake/task.rb:172:i
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rake-10.4.0/lib/rake/task.rb:165:i
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rake-10.4.0/lib/rake/application.r
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rake-10.4.0/bin/rake:33:in `<top (
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/bin/rake:23:in `load'
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/bin/rake:23:in `<main>'
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/bin/ruby_noexec_wrapper:14:in `eval'
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/bin/ruby_noexec_wrapper:14:in `<main>'
It looks like this importer needs quite a rewrite.
To be honest I’m not swimming in time these days (my daughter was born since I released that importer and you know how that goes… endless feature requests).
However, I can imagine more people would like to switch from Facebook Groups to Discourse (how can they not?), so I really like to have a look.
In the mean time: PRs are welcome! :slight_smile:
If we get a business hosting customer who wants to be imported from Facebook, we can take this on. So I encourage anyone interested to sign up for a hosting account :wink:
@codinghorror just signed up… (and look forward to being the test case)
In that case I think I’ll take a step back. No need to have two teams work on the exact same thing.
Hi guys
Due to my own needs, I almost fixed FB groups importer, but don’t have a solution to properly convert ‘created_time’ value from FBGraph. This value is needed when importer creates posts and topics. After importing from FB, this value looks like this:
"2015-02-01T19:02:49+0000"
and I don’t know how to convert to form accepted by PostCreator, here:
                         raw: comment['message'],
                         topic_id: topic_id,
                         created_at: Time.at(comment['created_time']))
Any clue?
Will publish new version of importer when will be finished.
Solved. Going forward…
DateTime.iso8601 method will do it.
http://www.ruby-doc.org/stdlib-1.9.3/libdoc/date/rdoc/DateTime.html#method-c-iso8601
Nice of you to pick it up! Could you make a PR? Then other people can use it too. Would be great.
Yes, figured it out 10mins later :slight_smile:
Please share! I’m sure many of us would love to use this.
Changed, working againg import module:
https://github.com/VannillaSky/import_facebook_into_discourse
Pulled request to original script repository
Does this plugin scrap the facebook group info or do you have to export all facebook group posts
and then import them into discourse?
Thanks! :blush:
  1. Plugin does not scrapping FB group info (description).
  2. You do not have to export all FB groups posts
In summary, plugin:
  • gets users who posted in particular group, and creates accounts for them in Discourse
  • gets post and comments from particular group and creates topics and replies in Discourse
    If you repeat import process, only new users/topics/comments will be added
Thanks for your reply
Will it import images posted on a faceook group to discourse?
How many facebook groups can you add?
Thanks again! :blush:
Currently, without images/attachments
In config file, you can point only only groupID, so its imports one group at once. But of course, you can multiply module (changing filenames and/or dirs) and make it usable in way you mentioned.
Thanks again for your help :blush:
Sorry just one last question please, can it work for fanpages or be modified to work with fanpages?
I think fan pages are a whole different beast. This script is really aimed at groups.
