@justin is experiencing an error when imported users try to log in to Discourse via SSO from their Wordpress site. The error occurs because the user’s email address already exists on the Discourse site, but the SSO process is appending a number to the username.
@simon suggests that this issue is due to recent changes in the Discourse SSO code, which no longer matches existing users based on their email address if it’s not validated. He recommends checking the require_activation parameter in the SSO logs, which is set to true for imported users.
@justin confirms that the require_activation parameter is set to true for the failed login attempts. @simon provides a temporary solution by adding a custom function to the theme’s functions.php file, which sets the discourse_email_verification filter to false. This solution worked for @justin and also helped @jesselperry resolve the same issue.
I’m working on setting up SSO on my community at https://community.productivityguild.com where my Wordpress site at https://productivityguild.com is set as the SSO provider. Everything appears to be working correctly for new user signups and for users who sign up for a Wordpress account manually. However, for imported users, I’m getting this error in the Discourse logs:
It’s true because the account already exists on the Discourse site. However from the looks of the error it is passing a new username over to Discourse with a 1 appended to it.
Wordpress debug logs don’t show anything out of the ordinary either. I’m not quite sure where to go with this one. @simon or others, have any suggestions?
I think you are running into a problem that’s due to some recent changes to the Discourse SSO code. If a user’s email address is not validated, Discourse is no longer matching existing users based on their email address. This is a good change, but is going to cause issues for some sites. I’ll look into finding a workaround for the issue.
To confirm that this is the problem, do you know if the users who are successfully logging into Discourse are having to respond to the Discourse activation email before they can first login?
If you look at the SSO logs on Discourse for your recent login is the require_activation parameter set to false? I’m fairly sure the issue with the SSO login attempt in your initial post is that require_activation is being set to true. Whether it’s set to true or false will depend on how a user has registered on your WordPress site. Unless users are registering through the default WordPress login system, require_activation will be set to true. Maybe this is the problem with your imported users?
Here’s a temporary solution that will be safe for your case if you are certain that the email addresses of your imported users are valid, and you continue to use the default WordPress login system for your new users. If you ever switch to using a front-end login system that doesn’t validate emails, you must be sure to remove this code. Try copying this function into your theme’s functions.php file:
add_filter( 'discourse_email_verification', 'wpdc_custom_email_verification' );
function wpdc_custom_email_verification() {
return false;
